Miller Welder / Jet band saw
Feedback: +0 / =0 / -0
Selling for a friend of mine. I know very little, technically about the equipment. They were procurred from an estate after the owners death.
If interested, contact me here, and I'll attempt to answer any questions. I may put you in contact with the actual owner if I cannot answer your question.
One nearly new Miller Millermatic 250x mig welder.
Less than 5 hrs total on machine.
Comes with one bottle, nearly full.
One spool with flux core wire.
Specifications:
Input: 200 / 230 volt 50 / 44 amp 7.7 Kw Single Phase 60 Hz
Output: 200 amp 28 volt 60 % Duty Cycle 38 OCV
Wire Type and Diameter
Solid Steel: .023-.045 in (0.6-1.2 mm)
Stainless Steel: .023-.035 in (0.6-0.9 mm)
Flux Cored: .030-.045 in (0.8-1.2 mm)
Wire Feed Speed: 50-700 IPM (0.64-17.8 m/min)
Overall Dimensions: 20" x 44" x 34" tall, 212 lbs.
$1900
One almost new Jet 7" x 12" HORIZONTAL/VERTICAL BANDSAW
UL listed motor
Heavy cast iron bow and bed
Hydraulic downfeed for ease of cut
Hardened and ground worm gear
Roller cabinet with built-in chip tray
Automatic shut-off after cut
STANDARD EQUIPMENT
Complete coolant system
Adjustable material stop
Bi-metal variable pitch blade
Vertical worktable
Chip Brush
Very low hrs.
Model Number
HVBS-7MW
Round Capacity at 90° (in.) 7
Round Capacity at 45° (in.) 4-1/2
Rectangle Capacity at 90° (in./W x H) 2 x 12, 7 x 8-1/2
Rectangle Capacity at 45° (in./W x H) 7x5
Throat Depth (in.) 7
Vertical Worktable (in.) 9-3/8 x 10
Vise Swivels 45°
Blade Size (in.) 3/4 x .035 x 93
Blade Wheel Diameter (in.) 11-3/4
Blade Speeds (SFPM) 80, 130, 180, 285
Bed Height (in.) 23
Motor 3/4HP, 1Ph, 115/230V, Prewired 115V
Floor Space Required (in.) 20-1/2 x 49-1/2
Net Weight (Ibs.) 318
$900
As these are fairly large pieces of shop equipment, buyer will need to either live in the general Portland, OR / Northwest area, or have a contact here for pick up.
