- May 30, 2006
Warning: this might cause some of you machinists to cringe, but I got a lesson this morning in what maker James V. Hughey calls "farmboy machining," and I'd like to pass it on to any other knuckleheads (unless I'm the only one?
) If it is unsafe, please advise. If you want to try this, please use caution and please do so at your own risk.
I have never found an easy way to make the slot in a guard. No matter what method I tried, it always took a lot of time. I'm visiting my in-laws in Anchorage right now, and this morning my father-in-law took me over to see another knifemaker he'd met here in town. His name is James V. Hughey - great guy. He showed me his method, and it just made me feel dumb as a rock for having wasted so much time over the years. Here's the method:
He uses an 8" drill press, a little desk size one, not a floor model. He chucks up a piece of square stock, brass or whatever, in a machinists vise. He centers the stock on the drill bit and clamps a brace (just a block of wood) on the drill table so he can drill a straight line of holes. Then he drills out the holes so that they overlap each other, which does most of the work for you (this is all pretty standard so far, and there's plenty of tutorials out there, some even with pictures).
I have never been able to make this method work - my drill bit usually jumps over into the next hole, or I get it crooked, etc. etc. He solves this problem by using the vise and brace, but then also chucking the drill bit up as far as it will go. He was only working with about 1.25" of bit. When he drilled the last hole, he lowered the bit all the way down and pulled the whole vise back, dragging the bit down the length of the slot. Basically he turned his drill press into a mill. Since the bit was chucked up so high, it doesn't break, and it ate through the rest of the material really easy. He was using this method n 1/4" stock. That's it, nothing fancy. In just a couple of minutes he had an undersized slot big enough to fit a file through for final fitting to the blade.
Gotta get back to my vacation - if anybody has any further advice, for safety or otherwise, please chime in.
If your advice is to use a mill for this operation, please just send me one and I'll do just that.
v/r, coty
v/r, coty
