Milling micarta and G10
Will this material hurt my bits when milling???
Or should I have one dedicated for these materials??
It is abrasive stuff. I generally use a rougher and a finisher so I get a consistent finish longer. You will want to make sure you have proper ventilation so you don't breathe the dust.
I rough synthetic stuff to dimension a lot on my manual knee mill. Micarta is not as hard as G10, on your cutters. Either way I just use whatever sharp HSS cutter I have laying around. High speed works well, feed can be pretty fast but watch out for the edges. I try to climb mill my way carefully around the part before roughing the center.
i use carbide and keep it wet to keep the dust down. i ll take short cutter life over shorter lung life (that dust gets everywhere )
We use carbide and run wet.
G10 will dull a cutter quickly where it can't be used for anything else.
What cutting fluid do you all use for Micarta? A machinist in the physics lab around work uses Ethanol or Alcohol, and so thats what I have used.
I'm only taking about a 32 of an inch off, just to insure it's flat after thinning my 1/8" material.
But I'll pick up another just to be safe.
Good point about wear from G-10, even for a non machinist. Remember that with G-10, you are milling glass fiber as opposed to some kind of cotton with Micarta.
I've been using my $100 carbide counterbore to drill tons of Ti bearing/pivot recesses... do one in G10 and it is noticeably dull!
