Milling MOP
GTC
BOUNCED EMAIL: I need to update my email address in my profile!
I never did an interframe. Other day this fellow told me that I could use his pantograph. So I'm asking how I could clamp/glue the MOP scales for milling them? If I clamp they could broke, if I glue it'll be hard getting unglued without breaking.
Thanks in advance
gtcknives.com
Use superglue and glue them to a thin sheet of steel that can be screwed down to a larger fixture. After they are milled you can remove the thin sheet and gently heat it from the underside with a torch and the glue will loosen and the pearl will be easily removed. You could also just soak the sheet in acetone.
Mitee-Bite sells some heat activated clamping compound that should work pretty well.
I've never done any MOP, but if was going to, I would try it.
Mitee-Bite
McMaster-Carr # 50245A21
