- Jun 11, 2006
Ok after much (days) thought i solved my die securing problem. I wanted it to be easy to remove but tight and not sloppy. so this is what i came up with and i must say it kicks A$$
. what do you think. i quickly heated up a 7/8" bar of steel to a dull red heat a gave it a squish. man it almost pinched the bar in half. The dies are made from HSS shanks cut off of broken 1" mill bits "rougher's". Let me tell you it was a pain in the butt to weld them as a cold weld kept cracking. so i finely just kept the ark on the joint till in glowed red then i started to weld. with the dies at a very very dull red thy finely welded and held great. so i now have a set of hardened HSS drawing dies
. here are the pictures. thy are very secure and are not going any where unless i want them to. now to make some more dies
