Lapedog, I would not order a high grit stone of any type grit. As I don't shoot for a high finish in my sharpening for daily cutting needs. I mostly strive for a general cutting edge. 3-400 grit. As I mostly cut apples, rope, cardboard, ect.. I don't work long on the edge. When it dulls I can
quickly bring it back to sharp by stropping. When this can no longer be achieved I take it back to a 300 grit stone for a touch up. I have a high grit Spyderco
ultra fine ceramic stone and rarely use it. DM
Clean edges cut better and are easier to restore and maintain, at any finish.
What would you determine to make the edge "clean". Is it to finish lightly on a significantly high grit stone after putting on a course finish? or is there a specific method to clean an edge on any said finish.
I've actually started an experiment on M390, Bencmade mini barrage. I've done the test for the course finish, 2000 grit diamond. I will be performing the test for fine finish in the next few days. I had the knife sharpened yesterday, but saw a flatspot, so i'll have to redo it.
I've always thought non leather workers over estimate the protection to being cut or stabbed that leather affords. Once an edge or point is sufficiently sharp it cuts leather VERY easily.
People who make knives some times wear leather aprons thinking this will protect them if a machine flings the blade back at them. Nope. Only chain mail.
Interesting discussion here for sure. In re the above, isn't there a difference between cutting leather (or any medium for that matter) and simply puncturing it with a tip? I'm asking because you mentioned "protection to being cut or stabbed" and I always thought those two things were not necessarily related. I might be going to far afield here, but if you look at something like kevlar, it can stop some bullets from penetrating, but the pointy tip of a knife is will supposedly penetrate with surprising ease. Yet does that mean that a sharp edge will cut it easily as well? I do not know the answer. I do know that a few years back, a knifemaker died when a knife he was grinding/sharpening flew out of his hand and lodged in his chest. I don't remember who it was or if he had any chest protective gear on, but I sometimes wonder if it would have made a difference given how sharp our knives can sometimes be.
That's a rough way to go man. I thought it was a rule of thumb to have the blade grind away from the user.
