- Aug 5, 2008
Currently you can get the "custom" Griptilians in 154CM, D2, N680 and S30V.Wow how did I not see the custom option before? What are the actual differences between the blade materials and are they noticeable?
I don't claim to be an expert when it comes to steels, but...
154CM - The Griptilian standard. It should be easier for to resharpen than D2 and S30V, but offers lower wear resistance, so you'll have to sharpen more often.
D2 - The least corrosion resistant of the group, but it'll make up for it by being one tough son of a gun and somewhat comparable to the S30V in other areas.
N680 - Of the four, I believe it is the most corrosion resistant. Beyond that, I really know nothing about the performance of this steel, but I would assume it probably offers the least wear resistance.
S30V - This steel should hold a better edge than the D2, but maybe not enough to appreciate. Like the D2, it will also take a bit more time to resharpen.
I've never really been much for combo edges myself, but if that is your preference, I would assume you would want high wear resistance to reduce the frequency of needing to resharpen. For that reason, I would suggest D2 or S30V. Another property that might be worth considering for the serrations is toughness to reduce the likelihood of chipping, but of course that depends fully on what you are using it for. So unless you are often using your knives in and around corrosive stuff or would rather not be wiping the blade off on your pants leg from time to time, I would say D2 might be the best route. Otherwise, S30V seems more practical to me.
But again, that's my non-expert opinion. I've never EDC'd D2 (though I too have been pining over a custom mini-grip in the stuff after handling a couple of Benchmade balisongs) but do primarily EDC 154CM, S30V and similar steels. I also have no real experience with Benchmade's serrations. By appearance alone, they certainly look like they would hold up better than most others that I have seen.
