mistake
blindref
BOUNCED EMAIL: I need to update my email address in my profile!
Dear sir's,Thank you for your very warm welcome to the new guy.And i can ensure you that my next purchace will be with (UNCLE BILL).Well here is the BUT have i made a mistake with this peice because i have this one already http://www.bkcg.co.uk/products/manu/kukri/ss01k.html Well i guess you live and learn,Please any comments many thanks BLINDREF:D :D
Your khukuri may be a perfectly servicable blade.
The description list the handle as bone, but appears to be and would usually be buffulo horn if not wood.
The few bone handles I've seen pictures of have more of the white or ivory look one would expect.
Critical points RE usability would be the strength of the tang / handle construction;
and steel quality / edge hardening.
Depends what you're using it to accomplish.
The harder the use (daily wood chopping at one extreme)
Or the more critical its dependability (military field carry at one extreme)
the more concerned you need to be with the quality of construction.
The fit, finish, and shape that gives it its 'look' may or may not be important to you; but...........
HI has this down, while still obviously hand-made blades.
The only concern I would have in a khuk I knew absolutly nothing about,
would be a tang failure around other persons.
A sharp 1-pound missle (blade lacking handle) bouncing around might be desirous to avoid.
A poor quality juncture between tang and blade --could-- fail when chopping hard.
The blade would seem to be made by stock removal rather than forging ("built from solid 10mm stock") which is
not in itself a bad thing, but for a current production 'traditional' khukuri --might-- be a sign for caution.
The best khuks will have differential hardening of the edge compared to the body of the blade.
The harder edge better retains sharpness, while the somewhat softer body is tougher to absorb the shock of blows.
Use the search function to look into these topics for more detailed info.
Or just browse back through the forum in depth.
Also see the FAQ at:
http://www.himalayan-imports.com/faq/
We prefer H.Imports because it's a trusted source.
By group experience we know the blade we get is guaranteed to be 'dependable / best of class' made by a small hand-picked company of bladesmiths.
Others here will have more to add.
Welcome.
Well first of all let me add my welcome to the others.:)
Dean covered everything very well, but let me give you a way to test the blade.
Take a really good file such as a Nicholson or Black Diamond and using a bit of pressure run it down the edge from cho to point.
It should dig in a little at the cho end and then start "skating" over the sweet spot then starting to dig in when you're a couple of inches (50mm) from the point.
If it doesn't start "skating" over the sweet spot that means it isn't quite as hard as it should be.
But if it barely digs in it's around 55-56 Rc and that's not too terribly bad.
Just makes it go dull a little quicker and needing to be sharpened a little more often, but the good news is that the chakma will align the edge much easier than it will if it's a properly hardened blade.
That covers the most, but my dear wife called me to dinner.:)
Blindref,
Welcome aboard! I have a couple of khukuris that appear to be made by the same company or very similar. They're perfectly servicable knives and will probably give you quite a few years of service. That being said, I think you'd be much happier with a H.I. Khukuri. Given what I know now I'll prefer them above all others! "Uncle Bill" has outstanding customer service and is great to do business with! I highly recommend Himalayan Imports, as I'm sure will everyone else.
Mike
I agree, they do appear to possibly have been made by Khukri House, the largest arun in Nepal, given the claims made. If so, you may actually have the equivalent of the British gurkha issue knife.
During WW2, each Gurkha regiment (?) had a kami or smith with it to make the khukuris for the regiment. That time is long gone. But at that time, the khukuris were delivered in the rough and had to be finished off to proper polish by the new Gurkha.
Today, there are two khukuris issued to each Gurkha. One with patent leather sheathe and highly polished and the other of standard sheathe and polish. Yours may be the standard issue for use in the field. If so, feel free after reading the FAQ's here to try it out. If nothing else, it will give you a taste for what the Gurka's often carry. it's certainly not to be distained.
I said often carry, as they are allowed to carry non-issue or formerly issued khukuris while in the field. Father hands his down to son, down to grandson, is as possibility. Or family has the village kami make one for the son going away.
Before Kosovo there was a picture of a British Gurkha sharpening his Chainpuri or Sirupati. Given most are recruited from the Rai and Limbu tribes, these are the style they would be most familiar with.
Stick around and you can decide if what Himalayan Imports sells is worth it to you, especially with overseas duty and shipping.
Welcome!
