Mitsuboshi Cutlery Ozark Trail Fixed Blade Knife Review
I was in Wally World and saw this fixed blade knife for $9.95. I figured, less than a movie ticket and if it does not cut, I can use it for a pry bar. The wood handle looked like crap, even through the plastic clam shell, so I picked up some tennis racket grip tape.
First, the disappointing features:
1. Plastic clam shell - I hate stuff sold in clam shells.
2. Nylon sheath - almost worthless, also stupid "Ozark Trails" label is sewn on the front.
3. Handle - thin, varnished and laser etched w/ "Ozark Trails"
As far as the problems above:
1. - As much as I hate clam shell packaging, it is a good excuse to use my contractor's utility knife.
2. I also used my CUK (contractor's utility knife) to slice off the stupid label. The sheath is barely usable, but it does cover the knife blade and is thick enough to protect you. Also, the knife in the sheath fits nicely in the back pouch of a Nite Ize Pockit. This inspired me to use the Pockit to store some fire making supplies along with the knife. More on that later.
3. Handle - thin varnished wood is not safe to use. The tennis racket grip tape solved the problem and also covered the stupid etching. It fits my hand nicely, it does not slip.
Once I got my hands on it, there were some good points:
1. Full tang
2. The top of the blade, where the handle meets, has 7 nice square cut outs. These make a great area to strike a fire steel
3. The blade is sturdy, about 5 inches and well balanced with the handle
Rough Use
The knife was predictably dull. Before sharpening it, I used it to pry a rock out of the ground and to dig a fire pit. It worked great and, for $9.95 it was worth it even if it never did anything beyond such rough use.
Sharpening
After that, the edge was really in bad shape, so I used a small metal file and re-created the bevel. Next my spydie sharpmaker and then a final hone on a color catalog. The knife was now sharp enough to slice the catalog to shreds. I have sensitive skin (and I am man enough to admit it!) so I did not dare shave with it.
A surprising feature
The square cut outs on the knife back are a great place to strike a fire steel. It really throws the sparks. Of course, it tears the steel to shreds, but, in a survival situation, I would go for the sparks. I can always get an extra steel.
Okay, that's enough for now. I gotta get outside. I will update this review and attempt to add some pix when I test:
Batoning
Fuzzy Sticks
Here is a link to the knife.
http://www.walmart.com/catalog/product.do?product_id=10298952
1. Full tang
Rough Use
Sharpening
Batoning
Fuzzy Sticks
