Ok Folks,...here we go....
memnoch,
Sorry, no black clip options. The clip is, however, nicely toned down in a matte ceramic bead blast. Its not shiny at all. Flat grey.
Also, the knife will not, ever, come from CAMILLUS set up for a tip up option. There are 3 reason. First and most importantly, safety. We just do not think that tip-up is a safe carry method for ANY folders using liner or frame locks. No mattr how good your ball detent is, the blade can be dislodged, and once it is, it is FREE to open on up. As we all know, other locks, the blade should be pulled back into the handle in this case, but in the frame lock and liner lock, once its dislodged at all, you have serious trouble on your hands. This is simply not acceptable. If you think that it can't happen to you, you need to think again.
Personally, I have had 3[!] instances of folding knves cutting me while in my pocket. All cases were with tip up carry knives. One custom, and 2 "semi-custom" . All three were excellent quality. All three had what would be considered VERY GOOD ball detent engagement. All three cut the $h1t out of me when I reached in my pocket. The SMALLEST one took the top right off my left middle finger knuckle. CAMILLUS will not expose its customers to those dangers.
No, I will not divuldge what model knives these were.
Secondly,
We respect other's patents. If the MAXX 5.5 were set up with tip-up carry-clip, you could "do the wave". It was not designed that way, as the two horns were clearly designed as guards. It wasn't until after DDR built the first one that we were even sure it would work as a Flipper. I believe it was Anthony Lombardo that first showed Darrel and I that it would open like the "wave" , if you put the knife upside down in your pocket. The comment was then made about some fool cutting his leg off doing it
Ernie Emerson has a patent on the "wave " feature, and we respect that, period.
Keep those cards and letters comin' folks!
