Model 10 from R. W. Clark in Liquid Metal (LM1)
Cliff Stamp
BANNED
The Model 10 in Liquid Metal (LM1) has a dropped blade, the primary grind is full flat grind on 1/8" stock with a v-ground secondary edge bevel. The blade is 1.3" wide and 5.25" long. The knife weighs 160 g and has a handle heavy balance centred 2.5 cm back from the guard. The spine is ridged just ahead of the handle, as is the end of the tang for security. A shot from the side :
http://www.physics.mun.ca/~sstamp/images/model_10_lm1_side.jpg
and from the top showing the profile :
http://www.physics.mun.ca/~sstamp/images/model_10_lm1_top.jpg
Fit and finish :
The edge is uneven from side to side and along the length. The thickness and width vary from 0.021 to 0.027 and from 0.029 to 0.039", the tip is strongly asymmetric due to the variance in edge width. The angle is however fairly consistent at 19-21 degrees. Under magnification (10x), the edge is clean no burrs, a significant and steep secondary edge bevel is present. The handle slab fit to the tang is perfect, everything is flush. The slabs are bead blasted to produce a nice secure yet non abrasive coating. The spine is squarish and fairly sharp.
Initial sharpness and cutting ability :
The Model 10 was quite blunt NIB (unused from the maker). There is a spot about one cm long in the tip region which reflects light. The knife scored on average 353 (46) on the light thread throughout the edge, and 5.0 - 5.5 cm on the 1/4" poly. This is about 25% of an optimally sharpened blade at a high polish (CrO).
The Model 10 had no ability to shave, slicing newsprint was rough, tearing could be seen along the cut, no ability to push cut the paper. On some 3/8" manilla hemp, 80-90 lbs was required with a rocking push cut through the tip, 90-100 lbs near the choil, and 40 (1) lbs on two inch a slice. This cutting ability is several times worse than optimal due to the low sharpness.
Initial sharpening :
A smooth steel was used to check the edge for alignment. The thread cutting performance did not significantly improve, however the length required to slice the poly dropped to 3.7 (0.1) cm . Checking the blade on some meats and fats in the kitchen, a lot of slipping was observed. The knife still had no ability to push cut cardboard and would just mash it down, slices were very rough. Thus it seems the standard tests of sharpness work decently well on the LM1 alloy.
A test was made with a few passes on a 22 degree jig to gauge the angle of the micro-bevel, it was far steeper than 22 degrees. To remove it, a 1000 grit waterstone was used. The metal worked easily compared to a few other knives which also had to be sharpened (various 52100 blades with more narrow edge bevels). The polish was then raised with a 4000 grit waterstone and the edge then stropped on CrO, 10 passes per side on loaded leather. Total sharpening time was about twenty minutes.
With the new finish the knife could shave readily, with just a hint of bite left from the 1000 grit stone (freehand skills are a little sloppy). The thread cutting was now very high, 108 (13) grams. The edge was checked 12h later to confirm the sharpness was stable, it again tested well 119 (44) grams. Thus there is no trouble in getting this material very sharp.
Going back to the manilla hemp, the Model 10 showed a massive improvement and now only needed 24 (1) lbs on a rocking push cut through the tip and 37 (1) lbs through the choil. The slicing ability had also improved dramatically and only 15 (1) lbs were required on a two inch draw.
Kitchen :
The dropped blade profile is perfect for kitchen work on a cutting board, allowing full and deep cuts. With the sharpness high the knife had no problems on meats, fats and various fruits and vegetables. The combination of decently thin stock and efficient edge profile produce solid cutting ability which fared well with most kitchen knives. The only drawback to a truly optimised kitchen knife was seen on thick and binding vegetables. On a medium sized turnip the Model 10 took 16 (1) lbs on a push cut while the Japanese utility knife only took 7.0 (0.5) lbs. The lack of rounding on the spine of the Model 10 could also be felt with the heavier push cuts.
The Model 10 was also used to take apart a medium sized turkey for meals, stock and soup. The handle stayed secure even when covered in fat and grease and was comfortable throughout the cutting. The thin tip easily penetrated the skin and meats efficiently. The upsweep was a bit high however for some cutting such as removing the breasts, which was done with the tip, the Pronghorn has a more suitable tip profile for that type of cutting. For most small cutting around joints, a Blackjack Small proved to be more efficient, due to the shallow nature of the cuts. No bones were cut this time as it was just an examination of cutting ability and general handling characteristics.
Edge retention :
The edge retention was checked on slicing 3/8" manilla hemp (no backing board) and cutting used carpet using a few other knives as benchmarks . Only a couple of runs of each have been done, a few more need to be performed to ensure a decently stable performance estimate, however initially the edge retention on those materials does not seem to be that of a decent quality steel. The edge retention will also be checked on cardboard and possibly on wood chopping and other harder cutting.
Handle ergonomics and security :
The grip has four inches of functional width, the contouring is heavy and very specific. It fits my hand well both in a grip out on the tips of fingers with thumb on spine for precise work, as well as in a hammer grip. With the contouring reversed into the palm comfort is reduced, but do to the radiusing, it isn't problematic. However I had it checked with a few friends of different hand sizes (larger and smaller), and had complaints of the finger grooves being less than optimal which is expected on a highly specific contour.
Sheath :
The Kydex sheath (0.055") is made in a pancake style, all seams match well and the edges are smooth. The blade locks in securely, taking ~8 lbs to draw. There is however some rattle in the tip region.
Blade material specifics :
This is a cast alloy, not steel but a Liquid Metal. The hardness of this particular grade, LM1, is 50 HRC, the impact toughness is 6 ft.lbs, and the yield strength 290 kpsi. For reference CPM-10V at 63 HRC has a yield strength of 375 kpsi and an impact toughness of 16 ft.lbs.
The edge is readily filed, holding the handle in the left hand with the thumb and index finger pinching near tip, the blade flexed readily. Bracing the blade against the heel of the palm it was apparent the blade could be readily broken in hand. This seems to be in line with the materials properties.
Questions :
Does anyone have a working email for the maker. I sent an email on use through both his website email and the contact info through his profile on the forums, it just generated a form letter which is months out of date. Some specific issues I am curious about are :
1) Tip limits, is the knife intended to be able to be stabbed into soft targets (phone book), medium (most woods), hard (plastics), and very hard (bone). What is the functional upper end for the tip strength, removing thick bark, prying or digging in woods, separating thick joints ?
2) Edge durability, with the current geometry, should the edge be able to cut thick plastics, chop hard woods (small diameter), used with a baton for splitting, accidental hard contacts (such as thick staples). How about with a more efficient 15/22 degree dual profile, and better yet 10/15.
3) How wide is the elastic region of LM1. How far will this blade bend before it will break. Is the ductility significant, will it take a decent bend before breaking?
Ref :
This knife is also on loan from Gabe Newell.
-Cliff
That's Mr. Clark's working email. His emailbox must be overflowing, but he will probably get around to answering you within a few months. At least, that's been my experience. A phone call may be quicker.
That addy should work, as I just got one of his #10's in S30V from the maker's corner sale page just within the past few weeks. His daughter is very ill, and I know that's been cutting (no pun intended!) into his working time and personal time...
And I also appreciate the review of the #10 in LM... I've been curious as to what others have found in this particular model, regardless of the steel.. I like the ergos on the handle (mine's in a beautiful Bocote wood but with a balance point somewhat different from yours) and I am partial to the blade shape... But I was curious as to the overall function - I realize the two steels here are vastly different, but the knife is otherwise the same and other than minor finishing differences, I, too, am curious if the point works the way Cliff has questioned it.. Okay... I've got nothing to really stick mine into, so I thought I'd find out what others have found...:)
So far, I've been very pleased with my version, and any who have seen it have also been pleased with the apperance of the overall package... Now... if I can just find something to cut besides those dang credit card offers...:mad:
:D
My 19 month old daughter was in the hospital with Spinal Meningitis for 14 days and was under home nursing care for 21 days. She is now fine with all signs of infection gone, her P.I.C.C. line was removed on Wednesday. However, I have been out of commission since my back went out again last week. This is the first time I have been up and around in several days.
Fit and finish. Whatever! I'm in no mood to even play these games.
"it was apparent the blade could be readily broken in hand. This seems to be in line with the materials properties."
Highly doubtfull! I have a standing bet at shows. If you can break this material with your hands you get a free knife. No one has been able to break it to date. This includes some really big guys. We have broken several blades in testing. This has been done by clamping the blade in a vise and bending it over the 90 degree edge. It regularly breaks at about 31 degrees.
"Thus there is no trouble in getting this material very sharp."
No really! You speak as if you are so familiar with "these types of materials" when it is clear that you are not. Due to the lack of carbides you can literally get an molecular edge. However, this is not the ideal edge for a general purpose light utility. Due to the lack of carbides the edge will slide and defect if taken to too high of a polish. I recommend no higher than 220grit for best general cutting. However, the doctors using these blades in surgery prefer a fully polished edge for cutting into materials such as human eyes.
When push cutting cardboard do not approach the cut at a 90 degree angle as you would with steel blades. You want to tilt the blade about 10 degrees to one side and let the tip trail by 5-10 degrees. Why this is, we have not been able to figure out. It is the same with slicing paper. It takes a little getting used to but once you get the feel it will slice all day long.
I am not going to spend all night answering questions that I have already answered before. All the information you need can be found at the following link.
http://www.bladeforums.com/forums/showthread.php?s=&threadid=236043&perpage=40&pagenumber=5
The testing done in this thread was all done with witnesses present and with photos. In the case of the testing with Trace Rinaldi it was all caught on video.
Also a real world evaluation is currently being under taken by Jeff Randell. He is spending 12 days hiking through the Amazon with a LM1 Model 10 as his primary knife. He will be doing a full review upon his return to the States. Last we heard from him was that he had just finished up some work with some anti-drug forces in Peru and was heading into the jungle on the next day. He is not due back for another week or so IIRC.
There is also another user review at the following link.
http://www.jungletraining.com/forums/showthread.php?s=&threadid=1585&highlight=clark
And here is the some links to information on Jeffs Peru Expedition.
http://www.jungletraining.com/forums/showthread.php?s=&threadid=1812&highlight=clark
http://www.jungletraining.com/forums/showthread.php?s=&threadid=1876
Edna and I are glad to hear that your daughter is doing better now, thank god!
As for you, heal fast my friend, you still have knives to make! ;)
Looking forward to Jeff's review on this exciting new alloy as well.
Cliff, keep testing...
Sheldon
I got a Model 6LM and am pleased with it. Hope the bad luck that have been dogging you get bitten and go away. All the best.
Ron,
Hope all goes well for you and your daughter. I really hate to see this kind of stuff happen. Keep working on that fit & finish thing, one day you will get it :rolleyes:
R. W. :
I can video tape it if you want to see an attempt at breaking it in the manner in which I described. If this was steel I would be positive it could break based on its stiffness, however Mission's Beta-Ti really surprised me with its ductility. It was easy to generate a set, but near impossible to break, it had to be actually ripped.
I am fairly confident however based on the way it bent and the materials properties, though in retrospect the exact wording I used in the above was a bit strong in that regard. I don't want a free knife, but would like a replacement for this one if it does break. If you do want to see done I'll have to check with Gabe . I would also rather wait until this one is used a bit more though, a week or so should be possible however.
If I can't break it in hand like I described I'll make a note of it here of course. Just to clarify I would not attempt that bare handed, I would be wearing thick gloves and a hard support to ensure the tip didn't penetrate the skin. I am also fairly confident that it could also be broken without a pipe and without body weight applied by stabbing it into a piece of wood and prying to the side (no gloves or support needed then obviously). A video could be made of that either if you wanted to see it.
This really isn't a practical advantage for most knives. The limit in sharpness for steel alloys is rarely approached, even very fine polishing grits are about one micron, *FAR* above the size of a molecule. Even fairly coarse steels like D2 can get a polished edge which can push cut free standing hair. The sharpening abrasives most people use are actually many times more coarse than the finer grained steels (~one micron or so).
So will any steel. Even coarse steels like D2 don't have enough of a inherent aggressive advantage to overcome the scratch pattern produced by even a medium abrasive like 600 DMT. Even D2 at a very high polish won't be more aggressive than 52100 at a lightly more coarse one.
what about if you need to cut something in a straight line?
It puts the material under tension and thus makes it easier to cut. You can see the same effect if you stretch the paper out and try to push cut it. Without the tension the paper will buckle under the weight of the blade, once the tension is applied the paper has the necessary rigidity to support the rupture pressure necessary to start the cut.
You can see the same effect by taking a steel blade and holding a piece of paper out in front of you. Using the knife (well sharpened) push cut down into the paper right next to your hand. This will be easy. Now start moving out away from your hand. At some point the knife will fail to make the cut because of a lack of rigidity in the paper.
It is also why over ripen tomatoes are hard to cut, the fruit body no longer has the rigidity to support the necessary level of pressure to force the blade through the skin.
This effect of angle on cutting is well known, you can slice at a 90 with a far blunter blade than you can push cut, and can slice at a 45 with a far blunter blade than you can at a 90.
There is also a secondary effect on material with grains (like woods) due to the massive difference in splitting a grain and cutting through one, angled cuts take advantage of grain splitting to lower the necessary force.
Thanks for the link, in regards to the tip digging and prying what was the penetration with the tip, it looked fairly shallow and not a lot of force was being applied :
http://www.imagestation.com/picture/sraid48/pf210b113a6f6b991576545562abb32f7/fcba716d.jpg
Specifically I was wondering about actually trying to dig a hole in a piece of 2x4 in a couple of minutes. If you go slow enough of course you can do it with any knife by removing small pieces of wood. How would the tip hold up under 1/2" or so of penetration.
The post also doesn't address the performance of the knife under more acute angles. Is the angle on this one the intended use as in the above 17 degrees is mentioned. You might also want to consider using a couple of other knives as benchmarks to put the performance in perspective as wood and bone can vary widely in hardness. Ideally you would have them heat treated by someone else, like Bos, this would then allow a fairly unbaised comparison.
From that thread :
Edge retention. The blade would start to dull and you could feel it slowing in the cardboard and then it would start to get better
Steel does this as well. I noted it years ago :
http://www.physics.mun.ca/~sstamp/knives/dendritic_aus_8.html
and more recently looked at it in some detail :
http://www.bladeforums.com/forums/showthread.php?s=&threadid=214104
http://www.bladeforums.com/forums/showthread.php?s=&threadid=226263
It is simply due to a saw being created due to fractures in the edge. I have meant to look at it with different steels and see if it was more or less pronounced from one steel to another, it would seem to be so. However it should also be noted that by the time this is happening, the knife is so dulled it is long past the point of wanting to be sharpened. You can cut cardboard for a very long time if you are willing to cut on a slice on a slant.
Back to the knife :
I forgot to mention the finish on the primary is very rough, you can feel it with the fingernail, grind lines running from the spine to edge. This may cause some performance loss due to friction, but I doubt it. It does however cause the blade to gum up on some substances, after the turkey cutting fats did stick onto the flats much more so than the other blades used.
The edge bevel while uneven, was very centered on the blade. With most hand ground blades, the primary grind is usually not even and results in one side of the edge having to be much wider than the other if the angle is the same. If you really want to see this to a large extent try a cheap machete. This knife had the most evenly centered edge I have seen in some time.
In regards to sharpening, I have fully sharpened it four times now. While it does machine easily, the sharpening time is well behind other blades I have with much thinner bevels. There is however a durablity concern with going to thin, I would not for example want to chisel through something hard with my 52100-MEUK, though it would do all the cutting noted in the above, with the exception of the leg bone chopping, depending on how hard the swings.
The paint can cutting is interesting, I have hacking into them with no damage before, I'll have to get a few empties and try it out with some steel knives, and talk to Gabe about this one. It will be another week or so before the edge retention work is done anyway.
-Cliff
Cliff, whatever. I will not waste time I could spend in the shop one your long winded drivel. And no when you break it Gaben will not get a new knife. Sending a knife to a known abuser for "testing" voids the warrenty.
BTW. Here is a photo I just took. It shows me flexing a 13" chefs knife to nearly 45 degrees in my hand. Thats all I can bend it. I have however seen really big guys flex LM1 blades to about 50-55 degrees without breaking.
Thanks Cliff, I've been very curious about LM.
What do you see as LM's niche?
I'm looking forward to more edge-retention work and toughness tests. So far it seems a bit like a more flexible talonite with less low-stress edge retention?
Interesting stuff :D
Just overlaid that photo on an angle chart. Based on the chart, the knife is actually flexed a total of 82 degrees. This is based on a total measure of tip to butt angle at the maximum degree of flex.
R. W. :
In that picture you are bracing the blade with your thumb and index finger, this concentrates the stress on the primary knuckle of the index finger (or your thumb depending on how exactly you are holding and pressing), which is fairly weak (relatively). The grip which I indicated was likely to break the blade braced the heel of the hand against the blade, this draws on the wrist for strength which is *massively* stronger and more stable than the primary finger joint. Try bending a steel blade of similar design and see if it flexes as readily.
Andrew, I don't think it is more flexible than Talonite, Simonich had a picture with a large bar of it bent across his chest. The Model 10 has a decent tip taper and is on thin stock, this inherently makes for a flexible blade. Plus a 31 degree break in a vice is not what you would call flexible, ATS-34 and similar blades get around 25. For reference Phil Wilson can bend his S90V fillet knives to 90, S90V isn't a flexible steel however, his fillet knives just have *very* extensive tapers.
So far it has not shown high levels of edge retention on carpet and rope which I would not expect given that its softness and strength are both well below cutlery steels. Yes the slicing aggression will be high if the finish is left really rough, as will any steel, mild steel knives can cut well for a long time with such finishes, and vastly out cut quality steel knives of thicker profiles and with finer polishes (though of course when compared to quality cutlery steels of similar finishes and profiles they don't do well).
It would look to be ideal for a knife which mainly needs a high level of corrosion resistance.
Compared to Ti, it is significantly harder (~5 HRC points), so it should take a more acute bevel and have better edge retention, though it won't be as durable impact wise or bending (Ti is really extreme in both cases, well Missions is anyway).
Compared to Talonite or Stellite 6K, it may not be as tough impact wise (the materials testing is certainly very low but it is not great for Talonite and Stellite either), but the flexibility is similar. It probably has the advantage in edge retention in most cases due to the slightly higher hardness.
Compared to a decent high stainless steel like 420HC at ~56 HRC, I don't see any advantage on most materials outside of the fact that these steels can rust, though it does take some doing.
It may be that with a really coarse finish the fractures which happen with wear take place in such a manner so that the edge retention is higher than with steels. I have not seen this with 600 DMT however. The drawback to such really coarse finishes can be significant though :
1) you lose push cutting ability rapidly
2) durability under push cutting and impacts is lost
3) you really chew through a lot of steel when sharpening, the wear rate can be 10 times faster than with fine finishes.
I don't have any 220 grit belts, but can look at 80, or 100, and x-coarse DMT, and 220 SiC. If 220 is some kind of sweet spot I would pick up a belt, though that would make a pretty narrow focus knife. Very interesting though if the relative performance was so grit dependent, I have never seen that before.
Suggestions are open as to where this knife is supposed to excell over a quality steel knife of similar design. A steel knife also would not need this severe of an edge bevel to do the things listed. I have done all of them and far more severe with knives with much thinner and more acute edge bevels like The Deerhunter.
-Cliff
Now I am not holding it right?! Cliff you are like a bad joke with no punch line.
Just for giggles. Here is a photo of the same blade bent to 98 degrees. It is wrapped around my grinders contact wheel. That was as tight as I could get the quick grips to go. Absolulty no damage and it rebounded dead straight.
Looks real flexible to me.
Makes me question this assertion by Mr. Stamp:
If I had to hazard a guess here, I would say that Mr. Clark has more knowledge of this material than Mr. Stamp.
Out of curiosity, if your bet is to break the blade with your hands why does it matter is it Cliff or any other "abuser"?
Especially if the test is videotaped.
If Gaben had broken the blade during normal use, the knife would be replaced without a problem. However, Cliff is an abuser to the highest degree. His goal is to break knives. Once a knife is sold breakage is a warrantee issue. If you set out to break a knife (which is Cliffs goal) the warrantee is void. Period, end of subject.
The bet is not an advertised thing. I bring it up when a potential customer questions the fragility of LM1 at a show. If they want to take the bet after watching me flex a blade, they are given glasses, gloves and a non-sharpened "junker" (it has a bad grind). We step outside and they have a go at it. The junker is still intact and I have not given away any knives. Only about 3% of customers have ever tried to break it. Watching me flex it is enough for most poeple.
Interestng new material. I haven't seen or messed with it, but the photos by the maker sure make a good point about its ductility and overall strength.
Which brings up an interesting point: why does ANYONE listen to ANYTHING Cliff has to say? As was pointed out in this thread, Cliff's sole purpose in his "testing" is to prove how macho he is by breaking knives. Persoanlly, I've always been more interested in *using* my knives, than abusing them and asking for another because I was too stupid to use it properly in the first place. And I truly have to question the sanity of anyone that would send Cliff a knife in the first place.
Just how did he get such a following, anyway? Is it because he has spent WAY too much time typing out crap and putting it on the internet? All that proves is that he has WAY too much time on his hands. His so-called "testing" is a joke, as has been proven time and again. Amazingly enough, all of his testing seems to lead to the same conclusion: the only "good" knife is a Busse, of whatever *flavor* is currently in season.
Now I know why I rarely, if ever, waste my time at Bladeforums. Geez.
Mr. Clark, you're to be commended for your efforts at debunking Cliffy-boy, but it's a lost cause. His stalwart followers don't have much to do with reality, and logic is prety much wasted on them as well. I'm glad to hear that your daughter is getting better, and I wish you and she all the best.
Be carefull: this material has has little or no plastic region. It is thus unlikly to take any amount of "set" (plastic deformation) before failure.
In tensile testing it shows failure at 2% elongation.
See caltech's data.
Correct, it flat out will not take a "set". It either fully recovers or breaks. This has been the problem with developing a solid LM1 frame or liner lock. You would have to cast in the bend in the lock. And the engineers in charge of mold development say that that is problematic. :confused:
The up side is that, unless you WAY over stress the blade, your knife will be good as new. Also LMTs lab tests have shown that there is no structural fatigue with repeated flexing. Frankly there are no grain boundries to fatigue.
