David Martin
Moderator
- Apr 7, 2008
I agree.^ This is why I think we'll see more of this platform. DM
We have a craftsman on here who will install a lanyard hole on any 110. I'll agree it is a good feature to have. DM
Good post, I felt the same way when I pick one up. Nice knives but as you say not a Buck 110 or 112. PrestonThe Crooked River and mini crooked River are just about the perfect modern equivalent to the 110 and 112. I have the mini crooked river, great knife, perfect updated version of the 110/112 , perfect in every way, except one.....it is not a 110/112. This probably doesn't matter to most, but if you really like Buck 110 and 112's like I do, it just doesn't feel the same, it just doesn't feel right being in the deer woods with it instead of a Buck 110 or 112. It cost me $200 dollars to figure that out.
wow I actually have the prototype to that iron wood (?) issue …
Lenny , Buck recently mfg. a 110 w/ screwed together construction. It is more of a dress knife and user feedback may not be forthcoming. Still, the door is now opened and we may see more of this type manufacturing. DM
I coudnt agree more.I would say that Buck has covered the modern version with the release of the Slim models, either select or pro. With a thumbstud and pocket clip, along with the lighter weight, it has definitely modernized the classic 110.
John
DittoSacrilege ….. Well generally in the past, posting info from other companies offerings was considered a line in the sand on the Buck Factory sponsored forum. But, the world is a different place from several years ago.
I took the OP to first want opinions of other Bucks that are almost as good as 110's but with different advantages ? Say like a S30v large Vantage ? Or David's 334s or GSA's 317s. Yes, those two are discontinued but can be found.
300Bucks
View attachment 1010566 View attachment 1010568 View attachment 1010569 View attachment 1010570 View attachment 1010571 The BCCI 30th Anniversary Aluminum 110 is held together by a pivot T-nut and screw set, and by 2 T-nut and screw sets in the butt end. The center of the knife is riveted together with a single rivet joining the handle slabs with the rocker sandwiched in between. The rivet ends are covered by the removable handle inserts. 5 variations of inserts were offered (Ironwood, white Ivoroid, Olive drab linen Micarta, Natural linen Micarta, and Charcoal G-10). The blade needs no bushing, and it can be squeezed between the handle slabs by tightening the pivot screw. Blue LocTite will maintain the adjustment.
The pivot T-nut is immobilized by an octagonal head which fits in an octagonal recess in the right handle slab. The tail end T-nuts are immobilized by their D shapes which key into D shaped holes in the spring holder.
The knife can use any 110 blade including the “old” Selector styles. The knife is the same thickness a regular 110 but weighs only 4.5 oz.
Would love to see something like this become regular production. Maybe provide an optional pocket clip that can be screwed into the holes at the butt-end of the handle for those who don't want sheath carry.
The holes at the butt end of the handle are pretty widely spaced, and the T-nuts are D-shaped in cross section, so a special clip would be needed. I prefer a tip down carry, so I am going to drill and tap an Aluminum 30yr. knife and install a standard clip like the one in the photo. The only drawback is having to remove the clip to change the blade.View attachment 1019183
