I've been meaning to make this post for some time & Harry's "Special Projects" thread reminded me it was overdue. One of the khuks I bought last summer was this "little" 12" Sirupati. (Made by Sher, with an 8 1/4" blade & sporting a 1/2" thick spine, only a khukuri khuk would call it small.
<A HREF="http://albums.photopoint.com/j/View?u=185132&a=1406520&p=24550497&Sequence=0&res=high" TARGET=_blank>
</A>
The buffalo horn handle was nicely shaped & fitted but at barely 4" long, including the bolster, I found it a bit short for my medium/large hands. With a 4-finger grip, my hand was extending onto the blade behind the cho. I could get a 3-finger grip on it, with my pinkie supporting the pommel, but the point on the top of the butt plate would dig into my hand with use.
Enter my Dremel tool! I first used a fiberglass reinforced cut-off wheel to remove the bulk of material & then switched to sanding drums to start the reshaping. Once I had the shape I wanted, I moved to hand polishing using progressively finer sand paper. Finally, I buffed the handle with a felt wheel on my Dremel using buffing compound. Anyway, here is the result:
<A HREF="http://albums.photopoint.com/j/View?u=185132&a=1406520&p=37050904&Sequence=0&res=high" TARGET=_blank>
</A> <A HREF="http://albums.photopoint.com/j/View?u=185132&a=1406520&p=37050905&Sequence=0&res=high" TARGET=_blank>
</A>
BTW, the flash & enlarged picture show some minor finish imperfections that aren't visible to the naked eye. Also, the patina that is somewhat visible in the picture of the whole piece is intentional, brought about by lemon & lime juice.
Because of the concealment potential of this "little" khuk, I decided to try my hand at fashioning a Kydex sheath for it. I am pleased with the results, particularly for a first attempt, and will probably make a few others as time permits.
<A HREF="http://albums.photopoint.com/j/View?u=185132&a=1406520&p=37050903&Sequence=0&res=high" TARGET=_blank>
</A> <A HREF="http://albums.photopoint.com/j/View?u=185132&a=1406520&p=37050902&Sequence=0&res=high" TARGET=_blank>
</A>
The first picture shows the blade locked in place & the second shows the way in which the blade must be drawn & inserted. The Kydex provides a snug & secure fit for standard vertical belt carry. However, since I have a few other carry thoughts in mind, I added the strap with a "lift-the-dot" fastener for extra security. A TekLok belt fastener with give the sheath multiple carry position options. I am also planning on either buying or making a shoulder rig for concealed inverted carry.
Cheers,
Brian
He who finishes with the most toys wins.
Cheers,
Brian
