That's why I asked what he meant. Without specific examples, we have no way of knowing the extent or type of modification.the only difference between a standard wharncliff and modified wharncliff should be the shape of the spine..
the cutting edge should still just be a straight edge, or nearly straight.
That's what I always thought the difference is. Wharncliffe has a straight edge (Like the Yojimbo); a modified wharncliffe has a very very slight belly (Like the Sebenza Insingo).
Is this not the case?
What do you mean by "modified Wharncliffe?" Can you give an example?
I see the main advantage of a wharncliffe or sheepsfoot blade as being that you cut with a leading point as opposed to a trailing one. By adding curvature to the blade, you certainly do lose that advantage, however you do gain different advantages. I suppose it comes down to personal preference and what you pan on doing with the blade. For general use and EDC, I would lean towards the modified wharncliffe. However if I know I'm going to be cutting a lot of tough material like leather (like when I'm making a sheath), I'll go with the standard blade shape.
I've decided on a wharncliffe blade shape - Looks less threatening around non-knife people I think.
Might wanna rethink your blade choice if that's your reason. The non-knife people I show my blades tend to find wharncliffe blades more threatening looking than something like most of the Kershaw budget line, the Tenacious and Endura, etc. They see a wharncliffe, and almost to a one the first comment I get from them is along the lines of "whoa, that looks like it's made with 1 thing in mind-stabbing someone".
