knifeswapper
Knife Peddler
- Sep 3, 2004
If you own / have owned a Moki traditional (specifically their VG10); what is your opinion of the knife?
I have a Moki Fish Owl. Fantastic quality. It could probably pass for a custom.
I have a Spire, a Moki-made knife sold under the William Henry label. It's simply the best made factory knife I've ever owned. GEC wishes it made knives this good. The fit is near seamless, the closest to custom I've seen in a production piece. The lock is solid, with no play whatsoever, and it disengages without any stickiness.
The Spire is a lockback, so I hope you'll forgive a couple of its details. I only included the picture to illustrate Moki's quality, not because I recommend this particular model.
I'll echo the other statements regarding fit and finish. Excellent little knife very close to custom quality. One detail I'll add; it is the smoothest action lock back knife I own. No blade movement after a few years usage.
Same model as Frank's but I think it's the smaller size and in Redbone.
PROS Superb fit & finish of the highest order, precise action, fantastic match-up line between tang and spring, almost seamless. The steel retains a very fine and sharp edge that is more than enough for pocket-knife duties.
CONS Don't like the Redbone scales! whilst they are well fitted and radiused they look garish and they actually flake somewhat, not good and I was very surprised. I'd like to get it re-handled but as it has quite a few pins and a lanyard hole I fear that nobody could dismantle it and re-assemble with such clockwork precision.
I have a Moki in the jigged red bone, and have noticed the same tendency for the jigging's fine, sharp edges to chip or flake away; the jigging is too densely arranged, leaving the margins between each cut very, very thin and somewhat fragile. I kept noticing little bits of it coming off in my hand. That's my only negative impression of the knife, and wish I'd bought one in the amber jigged (stag) bone, as per Frank's example above.
David Very interesting you have the same problem with the Redbone. I've tried a rub-down but it doesn't seem to stop the flaking. Think I'm going to risk a tea-dye job that might at least improve the horrible red/black paint appearance:barf...)
Thanks, Will
