Monadnock AutoLock 22-Inch Expandable Baton & Bianchi Baton Holder w/ Tek-Lok -- SOLD
Feedback: +1 / =0 / -0
Monadnock AutoLock 22-Inch Expandable Baton & Bianchi Baton Holder w/ Tek-Lok -- $OLD
IMG_20180208_193428.jpg IMG_20180208_193441.jpg IMG_20180208_193511.jpg IMG_20180208_193535.jpg
  • SKU #: MD-Autolock22
  • Baton MSRP: $131.35
  • Holder MSRP: $19.99
  • Tek-Lok MSRP: $13.00
  • Total MSRP:$165.34
  • Price: $OLD
  • YouTube Demo:
For sale is a Monadnock AutoLock 22" Baton. I added some grip tape to the end but it can be easily removed. The Bianchi holder fits it very well. It has never fallen out or slipped. The holder’s original clip was fairly weak so I upgraded to a Tek-Lok. The baton has never been used— it has only been carried.
Product Description
The Monadnock AutoLock 22" Baton is always ready when you are by utilizing a revolutionary cam and ball bearing action. Its exclusive, patented, built-in safety features make it easy to access, open, control and hold on to. Once opened, it stays locked open until you're ready to collapse it by pushing a single button, one time. Compact and comfortable to wear, AutoLock Baton is designed to be carried with you at all times. These batons can be used with virtually all standard baton techniques and tactics or training programs.
Specifications
  • Shaft Locking Mechanism: Cam and Ball Bearing locking action provides the revolutionary mechanism for locking the shafts in place.
  • Shaft Unlocking Mechanism: Recessed Push Button in end cap shifts a push rod, which activates cam surfaces allowing the ball bearings to unlock.
  • Shaft Material: Hardened, aircraft quality 4130 seamless alloy steel tubing.
  • Hardness: Striking surface hardened and then tempered to 48 - 54 Rockwell C Scale to relieve brittleness.
  • Tensile Strength: 240,000 - 290,000 PSI (Pounds per Square Inch)
  • Diameter: 1.0625 inches (2.70 cm)
  • Closed Length: 10 inches (25.40 cm)
  • Expanded Length: 22 inches (55.88 cm)
  • Weight: 22 ounces (.62 kg)
  • Firm Foam Grip: 1.125-inch (2.86 cm) diameter; tear strength minimum 82 pounds (37.19 kg) per linear inch, installed over knurled handle surface to eliminate slippage.
  • Handle Tubing: 0.875 inch (2.22 cm) outside diameter 0.083 inch (0.21 cm) wall thickness
  • Handle Finish: Black Chrome
  • Middle Shaft Tubing: 0.635 inch (1.61 cm) outside diameter 0.065 inch (0.17 cm) wall thickness
  • Middle Shaft Length: 7.10 inches (18.03 cm)
  • Middle Shaft Finish: Black Gun, Black Chrome, Bright Nickel
  • Small Shaft Tubing: 0.445 inch (1.13 cm) outside diameter 0.092 inch (0.23 cm) wall thickness
  • Small Shaft Length: 6.280 inches (15.95 cm)
  • Small Shaft Finish: Black Gun, Black Chrome, Bright Nickel
  • End Cap Construction: Machined steel end cap with a spring-loaded button coupled to a push rod with cam surfaces. 1.062" (2.70 cm) diameter x 0.625" (1.59 cm) long
  • End Cap Coating: Black Chrome Plating
Are you trying to sell this for the full MSRP listed or is there another price I am missing?
I clicked the publish button and hadn't finished editing. I edited the post to include the price-- probably will appear if you refresh.
I will take this. Please send your pp addy and i will send funds and a ship to
Thx Adrock
Sold to Adrock pending funds. Will update when sale is complete or item is still available.
