Gollnick
Musical Director
- Mar 22, 1999
Around Balisong Collector Headquarters, we've been having an office pool on which would arrive first, Monarch or Tachyon. Well, the answer came today: a mated pair of Monarchs.
The sheaths are extrordinary. Wonderful, quality leather. The belt loop on the back is rather tight, but I think it will stretch some with use. If you've got a thick belt, though, you might have problems.
The blades have the rather loud ink on them, yes. But, they are nicely ground, nicely polished, and shaving sharp.
The joints have just enough play to allow the blade to move freely without allowing any wobble. Perfect. The pins are polished down and just barely visible under strong light. They remind me very much of the old "Production Quality" days only a lot fatter. These pins are simply not going to break.
The lock open is tight and as solid as can be. This is the perfect example of why the balisong is the strongest and most reliable lock mechanism for a folding knife. The only thing stronger or more reliable would be a full-tang fixed blade.
The handles are heavy and fat. If you like Jaguar's handle geometry but are getting tired of replacing pins, then this is your dream balisong. Everything is nicely machined and has a very nice brushed finish.
The latch is reversible for either a Batangas or Manila configuration. However, the polishing of the handles was apparently done after the latches were already installed in the popular Batangas configuration. Yes, with just a small flat-blade screwdriver (not an exotic small torx) you could easily remove the pin and swap the latch over to the other handle. But, as they come out of the box, the screw head has been polished right into the handle finish and if it weren't for the slot, you wouldn't be able to see it. It's a great look.
Latch up closed is just a little bit loose. But, that's good. Because man can not create perfection. The indians used to deliberately make a mistake in the weaving of their rugs just so that they wouldn't be perfect since the gods would be mad if a mear human tried to create something perfect. Like those indian rugs, Monarch has a flaw: the blade has no kick and the edge hits on the inside of the handle when you close the knife.
It's a great quality piece of workmanship. About as solid and rugged a balisong as you can buy. IF only it had a kick.
