You crack me up. You are so hard core about how everyone else is over-complicating things and you make something like this.... You clearly have some fab skills and attention to detail. You can keep calling it simple since that seems to be your shtick.... but clearly it's not so simple.
This is simple.
Nice clean build
Does your stone clear the clamping thumb screw?
I really like that table too.
Hmmmmm. Simple? Jeffery, doesn't the angle change on your jig along the length of the blade?
Especially important in maintaing the correct degree of approach along a scandi ground blade? Does Tony do Trig?
All kidding aside I'm trying to wrap my head around the math and don't have a piece of paper handy.
Scandi grinds work on a grinder with a jig because you are only working with two angles. The belt vertical and you jig at 12degrees or so?
I like it, I have been thinking of something along this line, nice work. I see you have marked the stone 220, I am assuming you have other arms with other stones to exchange with. The amount of welding also will fit my skill level with a welder.
Thanks. I have arms with 120, 220, 320, 600 and 1000 grit mounted to 1 x 1x8" bar stock.
You mean you have five separate rod and plate assemblies that go with this set up? It seems like a lot of equipment and involved fabrication to perform what is basically a very simple job.
I think things to death myself sometimes. Fred
I like it. Some people, for what ever reason, can't do it free hand to save their life. I am one of those people. Perhaps I haven't been taught properly. But I like the stability of using a sharpening system.
I wonder if there would be a way to make the stone plates removable from the arm. Or is it just simpler to have a whole set already on the arms and ready?
Can sharpening angles be changed by screwing the heim joint up and down or are you set for a certain angle only?
Would you be willing to share the specs of this rig via PM or email so I may attempt crafting one myself?
