- Mar 9, 2011
Selling off a few more. Any questions please ask, I accept PayPal, all prices in CAD and include fees, but shipping is extra. Happy to ship international. Not looking for trades thank you. Please post in thread or PM. Cheers
ZERO TOLERANCE 0561 $225 CAD
The 0561 features a premium stonewashed Elmax blade with a plain edge and ambidextrous thumb stud. The handle has a 3D machined 6AL4V titanium frame-lock and a G-10 front handle scale. Never used or carried
Overall Length:8.75"
Blade Length:3.75"
Blade Thickness:0.16"
Blade Material:Elmax
Blade Style: Drop Point
Blade Grind:Hollow
Finish:Stonewash
Edge Type
lain
Handle Length:5.00"
Closed Length:5.125"
Handle Thickness:0.58"
Handle Material:G-10
Color:Brown
Frame/Liner:Titanium
Weight:5.98 oz.
ZERO TOLERANCE 0551 SOLD
This Limited Edition Zero Tolerance/Hinderer designed folder features a black G-10 and bead blast titanium handle. The blade is tumble finish with dual thumbstuds. "0551 Hinderer design Made in the USA" stamped on back of blade. Tip up carry. Strong lock up, nice detent and perfect blade seating. Includes original box and paperwork. Never used or carried
Blade Length 3.5"
Overall Length 8"
Classification Manufactured Knife
Weight 6.0 oz
Additional Specs
Liners Titanium
Closed 4.625
SPYDERCO PARA MILITARY2 $150 CAD
This Paramilitary 2 knife has a premium CPM-S30V flat ground blade with a plain cutting edge. The handle scales are textured G-10 for impressive strength and grip. Never used or carried
Overall Length:8.28"
Blade Length:3.44"
Cutting Edge:3.00"
Blade Thickness:0.14"
Blade Material:CPM-S30V
Blade Grind:Flat
Finish:Satin
Edge Type
lain
Handle Length:4.81"
Handle Thickness:0.46"
Weight:3.75 oz.
Lock Type:Compression Lock
SPYDERCO POLICE 3 $160 CAD
The Police 3 blade is flat-ground VG-10: a high carbon, cobalt enhanced steel that sharpens-up easily and retains its edge. Mid-positioned backlock features a David Boye Dent for added lock security.Has been carried and lightly used, only sign of use is marks on the clip
Overall Length:9.91"
Blade Length:4.35"
Cutting Edge:4.00"
Blade Thickness:0.12"
Blade Material:VG-10
Blade Style:Spear Point
Blade Grind:Flat
Finish:Satin
Edge Type
lain
Handle Length:5.56"
Color:Black
Weight:5.00 oz.
Chokwe (C132G) $175 CAD
Steel CPM S30V
Overall Length 8.5 " (216 mm)
Blade Length 3.75 " (95 mm)
Closed Length 4.75 " (121 mm)
Blade Thickness .125 " (3 mm)
Edge Length 3.375 " (86 mm)
Weight 3.7 oz. (104 g)
Handle G-10 / Titanium
Caly 3.5 G10 (C144G) $155 CAD
Steel VG-10
Overall Length 7.625 " (194 mm)
Blade Length 3.5 " (89 mm)
Closed Length 4.313 " (110 mm)
Edge Length 3.125 " (79 mm)
Weight 3.1 oz. (89 g)
Handle G-10
Military (all black) (C36GBK) $170 CAD
Steel CPM S30V
Overall Length 9.5" (241 mm)
Blade Length 4" (102 mm)
Closed Length 5.5" (139 mm)
Edge Length 3.687" (94 mm)
Blade Thickness .145" (3.7 mm)
Weight 4.5 oz (128 g)
Handle G-10
KA-BAR TDI (model# 1480) never used or carried $50 CAD
Overall Length:5.625"
Blade Length:2.31"
Blade Thickness:0.13"
Blade Material:AUS-8A
Hardness:57-59 RC
Blade Grind:Hollow
Finish:Black
Edge Type
lain
Handle Length:3.32"
Handle Material:Zytel
Color:Black
Weight:5.60 oz.
KA-BAR LARGE TDI LAW ENFORCEMENT W/ ANKLE HOLSTER(model # 1483) never used or carried $90 CAD
Overall Length:7.50"
Blade Length:3.625"
Blade Thickness:0.19"
Hardness:57-59 RC
Blade Grind:Hollow
Finish:Black
Edge Type:Serrated
Handle Length:3.875"
Color:Black
Weight:6.40 oz.
BOKER TITAN $50 CAD
The Boker Titan is a large but very slender EDC and work knife. It can be carried comfortably even in a tighter pocket, due to the slim profile. The flat ground drop point blade, and the bead blasted titanium handle combines minimum weight with maximum stability. The tip-up carry pocket clip is reversible, enhancing the versatility of this impressive piece. Never used or carried
Overall Length:8.375"
Blade Length:3.625"
Cutting Edge:3.25"
Blade Grind:Flat
Finish:Satin
Edge Type
lain
Handle Length:5.375"
Handle Thickness:0.32"
Handle Material:Titanium
Weight:4.10 oz.
User:Right Hand, Left Hand
Pocket Clip:Tip-Up
Lock Type:Lock Back
LES GEORGE VECP FOLDER SOLD
Never used or carried, no lock stick seems to have avoided the issues that some of the V1's have had
Steel: .150" (3.81mm) thick, CTS-XHP
Handle: Titanium Frame lock, .150 (3.81mm) thick
Back spacer: Grooved Black G-10
Ambidextrous thumb stud
Phosphorus Bronze washers
Drilled and tapped for tip up / tip down.
Hole configuration is the standard 3 whole pattern so if you want a different clip, you have a lot of options.
Lanyard hole
4.9 (124mm) long closed
Blade, 3.4" (86mm) long, CNC flat ground to .015 (.381mm) before sharpening
Hinderer Lock Bar stabilizer
BRADLEY ALIAS I SOLD
The Bradley Cutlery Alias 1 Folder Knife features S30V Blade Steel which offers toughness, superior edge retention and corrosion resistance. The standard 6AL 4V Titanium Handle is lightweight, durable and corrosion resistant. The Titanium Monolock is simple but offers extreme locking strength. The knife will ride low in your pocket thanks to the large, sleek carry clip. This knife has been used and carried but is still in great shape. Snail trails on handle and could use a quick stropping.
Specifications:
Blade Material: S30V Stainless Steel Hardened to 58-60HRC
Blade Length: 3.60 (9.14cm)
Blade Thickness: 0.120 (3.05mm)
Length Open: 8.25 (20.95cm)
Length Closed: 4.75 (12.07cm)
Weight: 4.10oz (116.23gm)
Handle Material: Bead Blast 6AL 4V-Titanium Scales; Blue Anodized Aluminum Barrel Spacers
Handle Thickness: 0.420 (1.07cm)
Lock Mechanism: Framelock
Blade Style & Opener: Modified Spear-Point; Anodized Aluminum Thumb-Stud
Stone Wash Blade Finish
Blade Length:3.75"
Blade Grind:Hollow
Finish:Stonewash
Edge Type
Handle Length:5.00"
Color:Brown
Weight:5.98 oz.
Blade Length 3.5"
Overall Length 8"
Weight 6.0 oz
Additional Specs
Liners Titanium
Closed 4.625
Blade Length:3.44"
Cutting Edge:3.00"
Blade Grind:Flat
Finish:Satin
Edge Type
Handle Length:4.81"
Weight:3.75 oz.
Blade Length:4.35"
Cutting Edge:4.00"
Blade Grind:Flat
Finish:Satin
Edge Type
Handle Length:5.56"
Color:Black
Weight:5.00 oz.
Steel CPM S30V
Steel VG-10
Handle G-10
Steel CPM S30V
Handle G-10
Blade Length:2.31"
Hardness:57-59 RC
Blade Grind:Hollow
Finish:Black
Edge Type
Handle Length:3.32"
Color:Black
Weight:5.60 oz.
Blade Length:3.625"
Hardness:57-59 RC
Blade Grind:Hollow
Finish:Black
Edge Type:Serrated
Color:Black
Weight:6.40 oz.
BOKER TITAN $50 CAD
Blade Length:3.625"
Cutting Edge:3.25"
Blade Grind:Flat
Finish:Satin
Edge Type
Weight:4.10 oz.
Pocket Clip:Tip-Up
Lock Type:Lock Back
Lanyard hole
Specifications:
