- Jun 3, 2019
Previous threads do not seem to quite address these questions....
Did a lot of driving around yesterday, and managed to obtain (used) both my critical-need shop equipment: a bandsaw and drill press
On the bandsaw: this is a Craftsman 12" 1/2 HP, single speed, saw (with stand - not benchtop). need to tune it up, and get a blade (or blades). the questions below come from my rather significant lack of knowledge on "optimizing" for different materials and cutting activities
First question: much of my initial need will be ripping and re-sawing activities on handle material - including resinous tropicals. so I get that I should look at bi-metal and maybe carbide blades, 1/2 inch for mostly straight cuts. got it. But on tooth count - tutorials on-line seem to indicate that for ripping and re-sawing work, you should look at low tpi - maybe 3-4 tpi. that just seems counter-intuitive to me: for low material loss and nice clean cuts leaving a clean surface, would you not want lots of really little teeth each with little offset? Or am I thinking about this wrong - and the real benefit of the low TPI is more related to their ability to sweep out the cut material??
Second question: not right away, but later, I will likely want to use this saw to do gross material removal on stock prior to profiling on a grinder. I am not against changing blades as needed for this activity. Bi-metal, high tpi (~18 tpi) ... got it. However, previous posts have indicated the need to slow down the blade when cutting metal. With a single-speed unit, I do not have that option. did I choose wrong, and am I out of luck with later using this unit to cut metal? Also, cant use cutting lubricant with this (rubber wheels). Is there a way I can adjust technique to use this saw to do at least gross material removal without things going badly?
Hopefully someone can chime in fairly quickly - would like to head out later today and pick up a blade ... at least to start with.
