I find that AEB-L warps when drilled soft so I dont do it.
It will warp with or without holes, it is a characteristic of AEB-L. But if you quench with heavy plates this solves the problem pretty much. You can temper with the blade clamped and that helps as well.
With AEB-L it will even move days after heat treating. I now have my slip joint parts in AEBL clamped in a vise and left there for several days until the steel stops moving.
I do use Carbide Burrs to counter sink all of the holes in my blades, AEB-L & Nitro-V after they are waterjet cut, them to Paul Bos for HT. Then to me....No problems yet with stress risers... stressing!It I’m cutting your blades on the cnc I will pop start jokes for free. I will also drill the holes for you as well, we charge a buck a hole. I have not had any warping issues from holes. I use a carbide burr to drill hardened steel or opening the popped hole to 1/8”. After that I use a carbide straight flute or a dagger point carbide drill. The burrs work super good but only on hard steel. If you use them on something soft thy gum up and rip themselves apart. I found this out the hard way when opening up some popped holes. The holes where hard from cutting but soft bases steel. I have a video somewhere showing how I do it.
I find its 50/50 if it warps. If it is going to warp it's going to happen on any drilled hole. It sounds like the way to prevent all of this is having a way to keep it straight for as long as possible but that doesn't help much if using LN.
Drilling (Or any machine operation) should not generate enough heat to affect heat treat. MANY machining operations are done to hard tooling to maximize precision, without ill effect.What is the impact of the heat generated drilling post heat treatment in respect to stress risers, stress cracking and such?
Im not sure if you understand my observation. The bit simply stopped cutting at all. After re centering and getting rid of the deflection, it cut easilyThere is no inherent problem with drills or mills deflecting when you push straight down on them. Them problem is your pushing (down feed) exceeds the rate at which the bit is cutting.
So you are suggesting slow speed, slow feed,and nearly continuous supply of coolant?
For what it's worth I like cutting wax. We used to use it in aluminum welding shops all the time. I find it less messy and it works well. Someone step in and tell me if there is a down side to it.
Agreed in general. In this particular case, I had planned to solder on a bolster and had only holes for pins for the scales done pre HT. We changed out minds, and decided to pin/glue the bolster - hence the need to now drill bolster holes in the hard material.To not confuse new makers who may stumble upon this post.
Drill your holes before heat treatment. This is a standard procedure in knife making and done by the best knifemakers.
Only drill a hole in harden steel if you forgot to drill a hole.
Some may choose to drill holes post heat treatment, that is their choice but it is not what most knife makers are doing.
Looking more closely, I observed some pretty significant deflection of the drill bit ... so apparently the hole had been started and mostly completed fairly off-center from the chuck, I un-clamped the blade, re-centered so that the drill bit entered the existing hole cleanly (no deflection), and !!!! no problem at all completing the hole. the bit cut steel immediately, and when breaking through, did not break. My guess is that something about the geometry of the deflected bit did not allow the business end of the carbide to really engage and cut the steel at the bottom of the hole.
So... here is my thought (conjecture for now): when drilling hardened material like this with a carbide tipped bit, get the hole well started, BUT then un-clamp and re-center the bit so that is is drilling at a clean 90 degree angle to the steel, then complete the cut.
