- Dec 8, 2005
I have run a couple of blades over my new Sharpmaker, and using the magic marker technique, I find I am not quite getting the right angle. So I ordered a set of diamond triangles. My main questions concern the use of this set. I have knives of 420, D2, and S30V. Given the fact that these are out of the box knives with no use yet, how long will it take on the diamond triangles to get to the 30 degree angle I am looking for? I guess I am re-profiling the blade, although I don't think it is a major amount of metal removal. Is the technique the same as for the rods that come with the Sharpmaker, ie. alternating strokes on the corners and then on the flats?
Secondly, assuming I get to a satisfactory 30 degree sharpness, and assuming light but normal usage of the knives, should I leave the blade at this angle, or put on a secondary bevel on the 40 degree setting? I certainly don't mind spending time touching up the blades, but I don't want to have an edge that is so delicate that I have to "start from scratch" every time I pull it out of the sheath.
Thanks for the assistance to a newbie to the field.
