Toothpick pattern. The blade is just shy of 3" from tip to bolster, and the handle is just shy of 4". Blade is ATS-34, scales are water buffalo horn. Fully fileworked backspring that continues onto the blade spine. Liners are fileworked as well. There may be a few small handling marks on it, but I haven't carried it (I'm the original owner).
There is an imperfection in the knife. If you allow the blade to snap closed, the edge will contact the inside of the backspring. It happened once, didn't dent the blade, but left a very small (1-2 mm) "flat" spot on the edge that you could see if you held it correctly in the light. I sharpened it out with a few passes on the Sharpmaker.
Two ways to get around this problem. One would simply be to not let the blade snap shut. The other, which I've tried and I know works, is to cut a very thin strip of rubber and snug it between the liners and up against the backspring in the offending area. That way the blade comes in contact with the rubber and doesn't hit the backspring, even if you let it snap shut. I use the same method on an old Laguiole, works like a charm.
I thought about peening the kick, but the tip of the blade is already even with the top edge of the liners, and if the kick was any higher the blade tip would sit above the liners when the knife was closed.
A new knife, of like style by this maker, without the mechanical imperfection, would go for $350. I'm offering this one for $250, including Priority USPS shipping. Most overseas destinations, and our Neighbors to the North, add $5. Paypal, no fees to you.
Thanks for looking.
Thanks for looking.
