This one (obviously this is not my picture)
I dont understand this knife.
Extremely heavy for the size (only 7 inches) , an edge so obtuse it hardly cuts anything even when shaving sharp, very (VERY) uncomfortable in the hand, and coated for rust resistance.... except on two absurd grooves on the blade.
Also, the saw works nicely, but is reduntant, since it is so ridiculously heavy you could chop with it.
Why? WHY?
Bonus super heavy points if you add a multitool in the pouch of the sheath.
I dont hate it because It was the best knife deal of my life, I got it for 28, a bargain. I would feel extremely underwhelmed and depressed if I paid full retail though, in my humble owner oppinion, not worth it at all.
TOPS claims this was their first knife for "operators" but I honestly cannot figure out how anyone would carry so much weight for such a knife, much less professional badasses that abide by the practical over anything else sense. If I was military I'd choose a Glock or a even a Mora over this any day.
All TOPS knives have ridiculously dull 25° per side edges, and they go on to worsen this with the low sabre flat grind... They can be improved...
In defense of these things I would say:
-Blade and grind straightness is exemplary for the price, even some Randalls feel a bit wobbly in blade straightness in comparison (my Model 18 is definitely askew at 3X the price)... I also had a BK-9 whose blade was heat-curved, and it is clear this won't ever happen with a TOPS...
-The edge can be re-ground thinner to a sharper angle, a real bear to do, but the heat-treat is excellent, and this definitely makes it worthwhile.
-The big groove on the 7" blade helps get the saw working, as the one flaw of these saws is the typical TOPS huge sabre grind, making a big flat side friction area that detracts from the saw's function. Having a sawback that actually works is not a bad thing if you want to save on the edge: The saw can be batoned with no issues...
-The Micarta finish claims to get grippier when wet, and somehow this seems to be true... I generally find their handle designs to be excellent, although this one is not quite as secure as the Hellion. The full tang gives out a bit of vibration when chopping, but that is the disadvantage of all full tangs compared to stick tangs, and it is nowhere near as bad here as on the BK-9: This TOPS knife you won't break batoning in any case...
-The paint finish is really, really tough, and the rough-pitted blade finish underneath absolutely should discourage you from stripping it... This paint holds up better than the Black paint on my Chris Reeves Jereboam, a much more expensive knife.
-The sheath is nothing special in appearance, but it is actually quite decent in function (except for a bit of plastic insert rattle on my Hellion, and that can be worked out): The velcro handle straps are often decried, but they offer the option of flattening themselves completely out of the way for snapless regular use, yet are far, far more secure than a snap if you use them (although slower and noisier): Again, the sheath on Randalls have these crap metal snaps that have no security at all, even when they are squeeze-bent to be tighter, and they don't hold securely at all in comparison...
-The 7" blade is not the best way to benefit from the bulk and weight, but this model's only alternative is 11"(!): A 9" model would have made more sense... Longer blades do give you sheaths with two pockets instead of just one... The TOPS Armaggedon has a much better grind design, but is exactly as heavy at 24 ounces as the 11" Steel Eagle version (I guess the wider blade hurts the weight: Even the Esee junglas is 22.5 ounces without sheath)... The Armaggedon has a sharply beaked handle that is apparently a problem when chopping, and the hard to sharpen recurved edge is a dealbreaker for me...
-Knife weight on the 107 is 18.45 ounces, sheath weight is 5.1 ounces: I agree this is very heavy, and not efficient for a 7" blade, but at least it is truly indestructible... The 11" version is 24 ounces (+5.5 ounces) with a 7.1 ounces sheath (the TOPS Power Eagle is 26.5 ounces, plus 7 ounces of sheath): For 7.5 more ounces (with sheath) on the 111 you do get a lot more, although the much bigger saw loses the efficiency enhancement of the blade slot (Why?)... A 9" version with blade slot would have made way more sense, with barely over 3 more ounces in weight...
The handle on these things is always superbly crafted: I hate the dullness of TOPS edges, but other than that they never felt like they were junk by any stretch...
Gaston
