So the pivot of a slipjoint just magically doesn't experience wear from friction?
Good point, that's fair. I guess it's just a simpler design. Are there washers in the pivot of a slip joint? Anything with a pivot will eventually wear out.
Now I like Benchmades but that sounds astonishing after all the broken springs I have read about here. I have never broken an Omega spring but I don't use my Benchmades as much as my Spydercos. Not saying I don't really enjoy my Benchmades, I do, it's just that the Spydercos are even more suited to my style of use.17 years of every day carry is a pretty good track record
I always have to bust on Opinels :I think your longest lasting would be probably an opinel. under normal use
You are not far off base with that...I always have to bust on Opinels :
Sure the Opinel will last long because it is seized up solid half the time from a single drop of water getting on the wood causing it to swell up tight. Can't open it or close it until it dries out. Into the drawer it goes in favor of something that can tolerate "extreme" environments such as . . . oh I don't know. . . having the blade rinsed off and getting two drops of water on the pivot.
Or . . . working outside in the rain . . . hahahah if I tried that with ANY of my many Opinels they would be unusable for a week. Sure there is the fool with it of submerging the knife in oil for a few days . . . WHY DON'T THEY JUST DO THAT AT THE FACTORY ! ?
OK I got it out . . .
thanks for tolerating it yet again.
I would be pretty concerned about a spring breaking and not being able to get it say thirty years from now. Assuming my Benchmade was my ONLY forever knife.
Slip joints benefit from a design that discourages people from flipping it open and closed while they browse the internet for their next knife.Good point, that's fair. I guess it's just a simpler design. Are there washers in the pivot of a slip joint? Anything with a pivot will eventually wear out.
A 17 year old Benchmade AFCK would very ,very, likely be a liner lock.
Throwing one more in there for the Buck 112.
It is my number 1 folder, and it will likely stay so.
Grib is good, steel is good and the edge-geometry is very good.
