As most of us are aware, Sheeple are generally afraid of sharpened bits of steel, they immediately go into defensive "he's got a *weapon*!!!" mode and instinctively start cringing and crying for their mommies like the wimps they truly are...
to combat this behavior, as illogical as it may be, many of us carry a dedicated "Sheeple-freindly" blade, a small, innocent looking knife that won't trip the hypersensitive defective "warning" sensors of the sheeple....
most Sheeple-Freindly knives share one common trait, a small, nonthreatening size, typically the blade length is under 3" (2.5" and less is more common)and they're usually plain-edge, as serrations ("teeth" ) also tend to trigger the sheeple's "Danger Will Robinson, DANGER!!!" reaction....
what i've discovered is that, for some strange reason, the Spyderco Rescue 93mm, a *fully serrated* knife with an almost 4" long blade (3 5/8") doesn't seem to trigger the "Panic" mode in sheeple....
strange, logically, it *should*, it has a long blade, it has serrations, the handle is black, all triggers for sheeple panic behavior, somehow, the Rescue just doesn't seem to scare sheeple, a good thing too, maybe this is a blade that will help discourage the "long blade=weapon" mindset...
i think it's the blunt-tip Sheepfoot blade, the lack of a "point" makes sheeple see it more as a non-scary "utility" knife
....ironically, i'd hazard a guess that a good defensive slash from a Rescue would actually be *worse* than one from the classic "scary" "pointy" knives the sheeple are so illogically terrified of...
what midsize to large blades do you find Sheeple-freindly? is it the blunted tip?
