Motor Noise
Ithink the bearings on the output shaft of my 1hp grinder motor is screwed. The bearing is making a clicking sound and has progressivly gotten worse in the last hour of use. anything i can do Ihave a syringe /diabetic and 3in1 oil ??? Dam motor is only 9 months old and 50 knives sucks.
Oil will not help if one of the bearings is missing or cracked. If it can be replaced, should not be expensive. If you keep running it, you most likely will mar the shaft and do permanent damage.
Good Luck,
Jim
