- Jul 31, 2015
Yes you could, but I like to use two pole switches and switch both hot and neutral.
To split hairs, does not have to be something else running on that circuit.
Any current flowing on neutral anywhere of the service can produce potential between neutral & a grounded object.
Several variables play into the mix, but several volts is not uncommon.
Code requires switching the 'hot' side at minimum.
Both sides may be switched if both circuits are mechanically linked & simultanious.
The thing people need to be aware of is the risk of shock from neutral. Even though they're tied together back in the panel there is real potential between neutral and ground if there is much current on a circuit.
To put it another way, you could stand barefoot on a wet concrete floor and stick your tongue on a bare neutral wire and have nothing happen, but then have someone turn on a shop vac on the same circuit and mess up your day...
