Hi Joe,
We received some CPM-4V, enough to make a Mule Team.
Hey Mattmanyam,
If Ed would make the steel, we would make the Mule. That's a lot of steel to make though.
sal
I didn't consider the logistics of making that much Damascus, but I thought that it sounded like a nice insert to the series, since a bunch are making such beautiful scales...
I'm still wanting to try 4V. There are some others but 4V seems like a steel I'd get along with very well.
A2 would make another good reference standard the same way 52100 was as the first mule.
CTS has a few like B70Phttp://www.cartech.com/ssalloysprod.aspx?id=4397 (powder CRB7) which looks good as a blade steel. BD4P looks kind of like 154cm but a bit different. CTS-PD1 should be like CPM Cruwear.
All good though they can all look small and meek compared to the mighty K390 mule. Personally I'm all for them as ultimate wear resistance isn't how I grade my steels as better, best, etc. It's important, but not the sole judge of steels. That's why I still like O-1, W2, and other steels that don't rate on the 10V scale of wear resistance yet are great steels. 4V looks really good as a pretty balanced steel ( non corrosive) that should be pretty tough and wear resistant. It should run above rc 60 easily and not lose toughness.
CTS B70P looks like a decent stainless that has a good balance and should take nice edges with a good grain structure.
Thanks very much, Joe, for going to the trouble to give me the benefit of your experience and considered thoughts about corrosion and patina and the folly of trying to compare all the different characteristics of each steel. And thanks for all the references as well.Hi Doug,
4V is a non stainless steel. It's tough making an accurate chart or listing of these steels for any one attribute. The fact is hardening temps, grinding methods, finishes and other factors can make knives of the same steel have different levels of corrosion resistance. Throw in all the steels and all the different possibilities and it makes accurate graphing difficult at best. rough guessing without testing is about all you can do. There are already charts put out by companies like Niagara that do this. Latrobe also has graphs available online. Having looked at most of them I have to say sometimes they will even contradict themselves so you can take it with a grain of salt. I do.
CPM Cruwear data sheet from Niagara: http://www.nsm-ny.com/files/CPM%20CRUWEAR.pdf
4V data sheet: http://www.nsm-ny.com/files/CPM-4V.pdf
Niagara knife steel comparison ( does not include CPM Cruwear) : http://www.nsm-ny.com/index.cfm?fuseaction=page.display&page_id=27
Carpenter/Latrobe graph for cold work steels. The Lescowear/PGK steels are very close in composition: http://www.latrobesteel.com/technical_alloycomparison.cfm?View=Results&CatID=1
Note: The graphs are fun but won't necessarily accurately show the results you may see in the steel prepared the way you have it in the knife you have in your hand. Some of the most impressive knives I've ever had used steels that didn't look very impressive in graphs like the ones shown.
It all biols down to the way your knife cuts, and sharpens. I take care of all tools in my possession and use them as they should be used so I don't really notice differences in corrosion resistance others might. All get cared for and therefore corrosion resistance isn't something I value or need. I even go swimming in the ocean with tool steel knives without thinking twice. I do like sharp, biting edges so I do notice differences in steel hardness, grain structure etc. much more than any other attribute. If it's for chopping I use the correct tool with the proper edge. If I pry, I don't use a knife. It's as simple as that.
Wear resistance as an attribute is something I pay attention too but it's not the end all either for me. I don't need K390 wear resistance, but it sure is fun.
I don't patina my knives. Even the high carbon ones that people seem to like putting patinas on. To me patinas don't look very good. I don't get them, you might say. The steels I prefer don't get real even , nice looking ones anyway. CPM M4 is an example of that. What patina is there tends to be splotchy and comes off during the next use. The steels that look half way decent patina'ed look better satin'ed or mirrored IMO.
4V, as I've stated I have no experience with. I'm looking forward to it though.
Joe
This is often not talked about, but very true. Get a $70 (ish) mule in K390, and you have a knife that will out cut and show better edge retention than 99% of all other production knives out there. Unreal.Look no further than the mule team program itself for evidence of this. It sells product at a much lower markup than regular production knives and uses production time that could be more profitably used on regular production knives with more demand and higher markup. The mules as designed were not meant to be kit knives as much as a platform used to test and compare steels using the same thickness, same bevels etc. The fact that it gives us some of the highest performing production knives ever made is almost besides the point.
I agree with you that it would be a nice addition to the series, but I too didn't consider the amount of time required, especially for a part time maker. Ed and I had discussed making Ed's very beautiful "feather" pattern and when we did the numbers, it would be 6 months of work for Ed, which becomes boring quickly. Knife makers are all renegades, (think of "herding cats"). They are knifemakers because the "available" is not good enough for them, so they're going to fix that.
sal
