Mete,
Good basic summary of heat treatment, thank you for taking the time to creat the site page.
One point I disagree upon is the Cryogenics statement, if you use liquid nitrogen at -100 F, yes it is not very effective except for retained austenite. Most if not all bearing manufacturers who use 52100 will use the liquid nitrogen process. If you use the -300 F cryo treatment it will give improved physical properties. Data supports the deep -300F cryo treatment over many years of real world applications.
Multi temper does give increased properties however, the knife making applications may not be beneficial. We find that with D2 and similar alloys, a triple temper will give much longer life (increased spall resistance) in many service applications. Warren Cutlery found that with their wood carving knives made from 1095, a double temper greatly increased toughness and edge holding.
Retained Austenite will change over time (long time, not tempering time) if the steel temperature is elevated to approx. 250F-300F, as you know the steel will grow in size due to crystaline structure of Martensite vs. Austenite. At room temperature there just is not enough energy for the transformation.
The hardening process is essentially a time-temperature-transformation process, which is illustrated in the T-T-T curve, which I am certain you have examined in your research.
Regards,
FK
