The Multitasker Series 3 Review Provided by www.702shooter.com
Lets start with the tool set and construction. The handles are made from medium traction G-10 and the sample I have is done in all black. All the metal components are coated in a black finish that from my testing looks like it will hold up well. By well I mean it will take a good amount of use to show wear but when it does it just makes you look cooler when you pull it out at the range. A knife, bit driver with multiple bits, plier head with (euphoric gasp) REPLACEABLE WIRE CUTTERS, and two sizes of hex wrench round out what could be referred to as general work tools. From there things get more specific to the MULTITASKERs true purpose.
To wrap it up I would say that as an AR-15 go bag/range gear/soldier multi-tool this would work very well. It is a quality tool that can multi-task very well as long as your multitude of tasks involve an AR-15. Multi-tools are designed to do many different things if the need arises and the proper tool cannot be found. But one of the biggest problems with multi-tool addictions is you end up with a multi-tool for everything.
Read The Entire Review Here
