Murray is one of my favorite smiths:thumbup: Which is why I am pleading for him to wear safety glasses!!!
12:05 - Did Murray say he refined grain internally with cold forging?
A common technique used by Japanese bladesmiths but seldom exploited by western cutlers is the process of cold forging. In simple terms cold forging is the mechanical reduction in the steel's grain size through force when the steel is below normal forging temperatures. Cold forging makes the steel denser. In its extreme, cold forging is done with the steel at room temperature. Amongst metallurgists, the value of cold forging is controversial, because the theory doesn't match up with reality.
Metallurgists argue that while cold forging does work-harden steel, the effects of cold forging are nullified when the steel is later heated to the temperature required for quenching. Further, they argue, cold forging will induce micro fractures in the steel that will eventually cause a hardened blade to fail under duress. I have conducted research that supports the attributes of cold forging in blades, and all highly respected Japanese bladesmiths incorporate the process. Japanese bladesmiths unanimously agree that cold forging enhances cutting performance in blades. In the final analysis, it is difficult to argue with the results.
Here are some thoughts and considerations. Carbon/mild steel laminates seem to really benefit from cold forging and do not generally show evidence of micro-cracking. While I have seen homogeneous blade fracture from too much cold forging, in 16,000 blades, rarely have I seen a laminate blade fail as a result of cold forging. I suspect that the softer outer laminations absort excess force and energy, thus protecting the inner carbon steel from over stress. On the other hand, I have purposely destroyed a laminated blade by cold forging it until the blade fractured. Therefore, the amount of cold forging is a factor that must be understood.
...the blades that I have experimentally destroyed required this procedure to be repeated many more times before the blades would crack. As a general rule, Yasuki White steel can withstand more cold forging than Blue Steel before failure... Again, in order for the student smith to appreciate the process and value of cold forging it must be experienced first hand.
I wonder why he wouldn't just use a full piece of high carbon steel instead of forge welding the tiny piece into the low carbon steel?
I think that he also does the laminate to make things a lot simpler to straighten, since these knives are absurdly thin. I think that's how it worked with his yanagi-ba, at least.
