Muscular Sirupati
My Shop 2, 20” Sirupati has been used on and off for the last three weeks. It is the last of the Sirupati with the suspect tang. It weights 909 g (2 lb) and has a total overall length of 21”. The blade is 0.4” thick at its thickest point. The blade spine to edge distance is much smaller than an Ang Khola or WWII model. This gives the Sirupati and eel like appearance. The Sirupati’s forward angle and belly are not as great as the WWII or Ang Khola’s. The Sword of Shiva is decorated with nice brace inlaying. The Chakma and Karda are about 6” overall. The smaller knife was actually beveled and sharpened.
The Sirupati is neutrally balanced. It feels more like a 15” Ang Khola (635 g) and much lighter than an 18” Ang Khola (967 g). The Sirupati is easily stopped even when swing against no resistance.
First the tang was tested. The flats of the blade was struck against heavy wood working tables and then against a large tree. There is a lot more vibration than regular chopping. The tang did not break and even the horn handle was undamaged (no hairline cracks).
The blade was chopping sharp out of the box. I sharpened it by free hand with the course Lansky stone, followed by the Spyderco course stone. It would easily remove hair off my arms in after about 20 minutes work.
On the first trip out the Sirupati was used to chop up fallen trees and branches, about 5-6” in diameter. The Sirupati chopped through these with no trouble. Penetration is not as good as the WWII or Ang Khola of similar weight. This is due to the more neutral weight distribution and less belly on the Sirupati. To test the tang some more I chopped the knife into the fork of a small tree. The diameter of the tree is about 4”. The fork caught the blade about 4” from the tip. I pushed on the handle with my full weight. The tree flexed but the Sirupati blade did not appear to even deflect. I applied more pressure by digging my feet in and was able to twist part of the tree off. Next I chopped closer to the ground on some particularly dirty branches (7”-8”). I stopped after seeing sparks fly off the blade. It was now too dark to examine the blade for damage.
No damage was found on the blade when it was examined at home. The knife would not shave hair. There is a slight burr running along the right side of the edge. This seems normal for me since I am right handed. The chakma was used to steel the edge. The Sirupati would shave after steeling. I finished off my lightly running the Spyderco white ceramic stones over the blades. I found two very small nicks about 0.01” in diameter after the Spyderco stones were used. This is probably from chopping what ever caused the sparks. The only damage I could find was that the butt cap was a bit crooked. I straighten it up but did not bother to apply epoxy as it was still quite tight.
The Sirupati excelled at trail clearing. I have a 300 m trail which needs to be routinely cleared so that the 4x4 does not get too scratched up. Mainly, dead branches on Spruce and Pine trees must be chopped down. The branches have a maximum diameter of 3” and are typically well dried. The Sirupati could cleave through or snap off the branches with one swing. After, the branch was downed the knife could easily be brought to a stop. As Cliff points out for this type of work energy is wasted in stopping the blade. The extra reach was valuable to keep me further away from the branches thus preventing me from scratching my hand up as well.
In summary I liked my muscular Sirupati and I must thank Bill for selecting the heavier one for me. The edge is easily maintained and seems quite durable. The handle is quite tough. The neutral weight balance makes it more versatile for task where heavy chopping is not required. If required the Sirupati can do heavy chopping. However, I do not want to dance naked with it. I would be very concern about slicing off a most valuable appendage. After all I am the only son in our family.
Will
Cool report Will!
Your Sirupati sounds very similar to the one I have that chopped through the nail without even being notched. It seems to have a shorter than average distance between edge and spine as well.
The other shop 2 sirupati I have seen (the one that broke) seemed to be a _bit_ wider than the ones you and I possess (i.e. a bit more distance between edge and spine)
These narrow blades seem to me to be a little tougher to sharpen due to the thicker bevel the thick-yet-narrow blade shape demands.
I too have had no desire to dance naked with the knife.
My bris was traumatic enough, right?
(sorry, couldn't resist)
Mazel Tov!
-Dave
"Smooth Bastard..."
Forgot to mention there was a small fold line on the tang. I filed about 1 mm into the tang and the width of the line decreased signifigantly. If it can take the prying that I did with it, the fold line should be a problem.
Will
hehehe.Light chopping,5" to 6" dia trees,3" dia limbs.Little knives.
Just a few of the general statements that the regulars here make without thnking aboutit anymore.
Good report Will.
I have that old CS Trailmaster I keep mentioning that at one time I "thought" ...Was... a Big knife.
I have lost all perspective of what a Big knife may be.Perhaps the 18" Ang Khola would now qualify as a big knife and the 20" to 22" AngKhola as its big brother.
Sort of like the Trailmaster and Recon scout.
If I thought I could "live" without my "Little" 17" Village Sirupati for awhile I would send it on a journey to visit each one of you,but then one of you guys would probably lose control And give into your urges And dance with it naked.
I am just not gonna take that chance.
There are just too many of us that sometimes forget to take our medication.
La da deela dee da la dee lade da dee.Don't take it any further,if you do then you will get a visual and snort Pepsi or any given brands of Good Beer through your nose.
La de da de la dee da dee.
>>>>---¥vsa---->®
The civilized man sleeps behind locked doors in the city while the naked savage sleeps (with a knife) in a open hut in the jungle.
Himalayan Imports Website http://members.aol.com/himimp/index.html
Dave,
The khukuri's I have received have all been excellent. A few of them stand out above the rest.
Will
Oh by the way Dave,speaking about dancing naked.........I picked up some #8..1 1/2" Stainless Steel,Phillips,pan head screws today.
I also done some polishing on the blade prior to getting it ready to put the handle back on.I have to cut the aluminium bronze and shape it to the handle before I do that.
The a/b is a Lot tougher than brass. It is a pretty metal.
I will use it on yours and the other one that shouldn't take as much work to put back together.I hope.I am sure sorry it has taken me so long on these two.
I am gonna get some mild steel about 5/16" thick for my 18" AK though if I decide to do it.
The way Pala talks about the Gelbu Special it may become my favorite.
I may have to change the butt cap out on it if it does take the place of my 18" AK.I know the G/S is going to have to be a very,very special Kuhkuri as Pala has said to change my mind.Everyone knows I think the 18" AK is the best knife in the world.
>>>>---¥vsa---->®
Yvsa sir, please, please, _please_ do not apologize about the "wait" on the sirupati.
It has only been a few days really.
When I had my spinal fusion, it took six months before I was really even back on my feet again, and about two _years_ to be really pretty well healed up.
You are much more knowledgeable and _way_ more experienced than I am in these matters so I would feel very weird if you were to ever feel in any way like you owed anything to me.
My point of view is that I am totally thrilled that expert individuals like you and your cousin are going to be fixing the knife back up to better-than-new condition, and that I may actually be able to trade or buy it back instead of Uncle Bill just sticking it under his bed. (which is what I would do if I were him...)
So far life has taught me to wait at least two years for anything important, so it would only be after two whole years had elapsed that I would actually begin to really wish I could stop waiting.
If there are more important things for you to do please ignore the silly little knife. Throw the damn thing in the river!
It will all get done only at the appropriate time, and not a day sooner.
(sorry sir, I will get off my soapbox now and stop lecturing my elders...)
-Dave
Dave K - I have a friend who claimed that at his bris the mohel not only did the job, but also "took too much off the top" as well. So much for dancing naked though Yvsa and Chiro and Jim might get their heads together and do a braintanned loincloth with a built in hidden pocket to hold a kydsx liner ( substitute rawhide for the kydex, you traditionalists. That oughta give a little protection to you worrywarts.
You know Rusty,I think some good Thick Rawhide would make a wonderful
almost punch proof scabbard.
I have been told that the Mormon Tabernacle's original areas have Rawhide wrappings to hold the old timbers together instead of nails,because iron was so dear back then and there.
The only problem is that when it gets wet......
Thanks Dave.
I am anxious to get it done though.
I am really trying to get some heavier butt caps for those of us that like to beat our knives up.
I am hoping if Pala could see this we might help that along somehow.
That's a new thread though.
I will start it.
>>>>---¥vsa---->®
Dave’s and Rusty’s posts jogged my memory, so it was back to the dusty shelves of my library to find, in a scholarly work by Jerry Silverman, this old song, sung to the tune of “When Johnny comes Marching Home.”
A little bit off the top
When I was eight days old my boys, hurrah, hurrah,
The rabbi came with a big sharp knife,
And I surely thought he would take my life,
But all he took was a little bit off the top.
O that is what they call a bris, hurrah, hurrah,
And if the rabbi doesn’t miss,
It makes for an interesting ****,
The rabbi he is called a moyl, hurrah, hurrah,
and over me he sure did toil,
If he’d cut off more I’d be a goil,
O circumcision is all right, hurrah, hurrah,
But every morn and every night,
you aim to the left and *** to the right,
So the only question left then is which khukuri would be most appropriate for the procedure, right?
(sorry, I couldn't resist)
-Dave
"Smooth Bastard..."
