- Feb 27, 2019
I just sharpened a 4.5" blade after dulling it on the bottom of a coffee cup. The knife is sharp, but not "razor sharp." It will cut paper, but only after I saw to get it started. Here's what I did:
400 grit stone:
1. 10 "edge leading" passes on each side. I could feel a tiny amount of burr on the left side of the blade, but not much at all on the right side. I really leaned into it too. I removed all sorts of steel if the color of the water on the stone is any indicator. I ran new water over it and knife regularly so it didn't build up.
2. 12, 10, 8, 6, 4, 2, 1 - strop passes on each side. (edge trailing)
1000 grit stone:
1. same stropping passes as #2 above
3000 grit stone:
1. same stropping passes as #2 above.
Again.. the knife is sharp but not as sharp as I would like to be able to do. I am open to any advice on my process!
B
400 grit stone:
1000 grit stone:
3000 grit stone:
B
