- Nov 2, 2008
youre the richest hobo i know!!
j/k
nice set up man!
nice set up man!
Very nice!!!
I love these stoves. I just built one and got a 3:10 boil time for 16oz of water. Although I haven't figured out a windscreen/stand system yet
Nice set up! Ive built 4 stoves in the past couple weeks..Just toying with differant set ups. My favorite so far is one I built out of a screw top tin from specialty bottle.
here it is- http://www.specialtybottle.com/index.asp?PageAction=VIEWPROD&ProdID=227
It actually burns longer with an oz of HEET then my pepsi cans Ive built. Just unscrew the top, fill, replace and go! Ive been using high temp silicone to seal, and havent had a issue yet. They work nicely... Do you cover your cup with anything? Nice pot stand too!!
You get boil times like that out of a GSI cup bro? How? Mine always seem to take 6-7 min to boil. Id really like to get a speedier boil time from mine. Do you use a wick in it?
Anyone experimenting with these needs to do research first.
Using a sealant is fine (but not really necessary), these stoves run on pressure.
If you dont have enough holes they can blow apart scattering flaming alcohol about. Too many holes and too big of holes and it wont work at all, not enough pressure. The balance seems to be many very small holes.
If you dont have enough holes and the halves are sealed then the pressure gets way too high before blowing apart, very dangerous.
You can build the stove fill it full then let it burn completely out.
Do this outside. If it survives then seal the halves together.
THEN REPEAT! The excess gas may have escaped through the unsealed seams the first time.
Just be safe.
I would prefer to buy the Vargo titanium, its about the same size and engineered for this. Yes it cost more than an empty can, but it cost less than an ER visit.
