Discovered recently a bit of controversy surrounding Crucible's S35VN steel, and CR's heat treatment of said steel. Since I recently purchased a lrg Insingo in S35VN, that had me a bit worried. But like all people of free will and open minded thinking. I decided to see for myself if this steel was, to put it frankly - craptacular, or was (hopefully) an ok steel for my needs. This was all spur of the moment, not something I planned to document, was basically for my own peace of mind.
But after a bit of cutting cardboard, I felt compelled to post my personal experiences using CR's S35VN....
Test consisted of a medium large 24" L x 16" W x 10" H sized shipping box from a past order.
The Insingo edge was basically factory + sharpmaker touch up. In other words, able to shave arm hair nicely.
Aftermath of cutting the box:
I sliced printer paper to see if it was still sharp. It did fine, however, there was a very small, I guess you could call it a micro burr, that could be felt but not seen. I've had M390 steel, S30V, 440C, 1095, 154CM, and 12c27 - all those steels, as soon as I did any semi-aggressive cutting - cardboard, wood, or whatever I was cutting at the time - they all lost their initial super sharpness after relatively brief use. The CR Insingo seemed no different, at least in that regard. To me, the important factor was the Insingo still retained a very sharp working edge.
I decided to see how well the working edge held up after another box. If it would still be able to slice paper cleanly.
I was able to cut this much (about half the box) before it wasn't cutting as smoothly.
After that I tried to slice some printer paper. As you can see it no longer sliced cleanly, ripping the paper a bit.
The edge was still plenty sharp enough to work with, it never dulled completely. In fact, I was able to restore the edge to hair popping sharpness in a matter of seconds. 12/13 strokes on the Sharpmaker was all it took. Isn't that something people celebrate on a premium steel ? How easy/quickly it was to restore a razor edge ?
All in all, I wouldn't say I'm ecstatic with S35VN. But I am pretty content with it's performance. I mean, it did cut quite a bit of CB before it no longer cleanly sliced paper.
