I have two particularly treasured small fixed blade knives. In keeping with your 'small' criteria, Both are 7.25 inches long overall.
The first is a 'boot knife' with stag scales by Mastersmith Jim Crowell. Forged from 1084 steel, it has a drop/spear point blade (sharpened only on one side and assymetrical enough to have some belly on the edge). The knife has a very long blade for a knife this size. The flat ground and hand rubbed satin finished blade extends 4 inches in front of the stag scales. The handle seems a bit small at first, then you realize that it is short enough to place the butt of the knife In your palm, making this a Very useful and versatile tool. The spine in the ricasso has perfectly filed horizontal grooves. This helps index the knife in ones hand, a useful feature since it is easy to confuse the sharpened side of the blade in the dark. The knife is distally tapered, and also has a tapered tang. The scales are attached with two domed pins and a large steel lined thong hole. Grinds are perfect. Interestingly, the balance point is exactly on the front pin of the scales. This knife feels great in the hand and cuts everything well. Because there is no guard, it fits into a very small pouch sheath. This knife is almost unoticable when worn. And can be tucked in a pants pocket without any difficulty.
My second favorite knife is a Bird and trout knife made by John Perry. Unusual for me (I love forged carbon steel knives), this knife is a stock removal masterpiece in ATS-34. The satin finished hollow ground drop point blade is 3.25 inches long. The desert ironwood scales are attached by copper tube and steel rod mosaic pins. This knife really likes to go fishing with me. It is little handle heavy, but that feels right in a small knife. the handle fits my hand extremely well in several grip postioons. The best feature of this knife is amazing file work. The spine is worked from just behind the tip to the end of the knife is a perfectly shaped stacked vase sort of pattern. The curves are perfect, and symmetrical from side to side. After you look at it for awhile, you realize that the scales fit Flush with the file worked spine. To accomplish this, the scales would have to be machined in a exact opposite manner to the tang of the knife. There are no glues lines, gaps, or filler. This knife is perfect in every way. The knife is also guardless, and rides in a very compact tooled sheath.
I really wish I had a digital camera so I could post pics. Hope you can sort of see them from my descriptions.
Paracelsus
[This message has been edited by Paracelsus (edited 05-20-2000).]
