BM is sending out parts now?
I own a Benchmade 2750, STOP and oil the action. I had that problem upon first receiving it now it works beautifully. My locking bar is not abrasive, but if it bothers you could sand the edges of the locking bar (Rust forming I imagine would not matter because not load is on the outside of the locking bar (?blueing pen?)). You must remember this knife was designed for the RANGERS, who sometimes use gloves. So yes it can be uncomfortable but it had to work with gloves so the jimping had to be sharp. This can be a positive with us civilians when we work outdoors and the woods. I EDC the auto version and you will get used to it and won't notice it. Enjoy your sweat knife. Sorry if I don't sound kind I don't mean to be.hello
im small collector (10+ knifes)
and i have blades from all big knife companies.
it was first experience with BM and i was very curios how it will be
since BM is well known knife company for quality knifes.
however
i open the box & took it to hand i immediately
noticed just how damn sharp are the axis lock buttons, really abrasive..
to the point i just put the knife down, i try closing & opening several times
later thinking i try it again, but it left me with irritated & sore fingers.
it is also not so easy to close it one handed,
i understand the 275 omega lock is extra thick,
and probably would be assayer with bit of practice
and after it would have loosens up, but
the axis lock studs are a pain to handle
and ruining the hole knife experience for me and its a shame its impressive knife.
it's most expansive knife in my collection & by far the most uncomfortable & abrasive.
is that normal for axis lock, or normal at all for A BM knife, or for 275 adamas?
PS i head the axis lock LOCKED up open completely one time & needed alot of force to disengage it.
disappointing.
I think you may have missed part of the thread![]()
His knife has AXIS bars which are unusually sharp as they should not be scratching wood like they are, and Benchmade has sent him a replacement. I tried to replicate that with about 20 Benchmades I had that were closest to me and none of them did anything near to wood what his did, even with lighter pressure.
A good lubricant will help here a lot (Nano Oil's thicker weight lube or DuPont Extreme Fluoro, for example).
Call Benchmade, they'll take care of you if there's a problem.
Are you using both sides of the axis bar , or just one size?
I had an Adamas for a short time and didn't find this to be true at all.
well i have mechanical oil which didn't help, but silicone spray oil made it smoother
is silicone spray oil is good enough, or nano oil will be any better ?
thanks.
:thumbup:
I have not used a lot of silicone sprays, but thus far, I've not really found anything as good as Extreme Fluoro, and most other lubricants are far and away from even being in the same ballpark.
Extreme Fluoro on both sides of the PB washers of an AXIS lock, at the metal contact points where the lock bar makes friction with the steel liners and blade, on the omega springs, and on the outside of the pivot makes AXIS more smooth and consistent than a Chris Reeve Sebenza. It also greatly reduces wear over long periods of usage. And unlike most lubricants I have used, it resists migration and evaporation so it will run the knife equally smooth for months on end without progressively losing the smooth opening and slowing returning to not as smooth, ultimately resulting in a need for more frequent application with a liquid product, and excessive fouling.
The other reasons I like it is due to it's ability to bind with metal and not attract dirt like most wet lubricants and most greases do. It addresses the primary issues with grease (fouling up, poor initial performance, and poor cold performance) while still maintaining the many advantages grease has over a spray or wet lubricant.
You don't hear about Extreme Fluoro much in the knife world, but it is hugely popular in many industrial applications where a good lubricant is mission critical to avoid wear/damage, like with couplings, high sped bearings, and ceramic bearings. It sounds like a very small detail, but upon application the difference it makes is immediately clear and it becomes hard to use anything else. I like Nano's products and I like their grease a lot, but I still don't think it compares to Extreme Fluoro.
