The bushing has play by design and this is a function of that play. Is the knife solid while locked? If so, it sounds fine. Just don't want to see someone send their knife off for 8 weeks to get the same knife back lol. I'm just guessing at the 8 weeks, but I don't see it being a quick turnaround, they're pretty busy.One last thing... I'm not being nit picky, right? If the blade is in the locked position and I disengage the lock, I can feel side to side play (minute) like a semi loose pivot screw. At 90 degrees to the handle, if I push the blade towards the top of the knife (up and down) i can feel slight movement as well. I don't want to send it in and have them send it back saying it's fine, but if it can be fit better, I'm all for it.
Yes, it's solid on lockup. I don't remember my other Sebenza having any play with the lock not engaged. I was under the assumption the bushing was to fit the blade without any play as well as the pivot bolt. I'm OK sending my knife in if they can get rid of the play, if that's normal...The bushing has play by design and this is a function of that play. Is the knife solid while locked? If so, it sounds fine. Just don't want to see someone send their knife off for 8 weeks to get the same knife back lol. I'm just guessing at the 8 weeks, but I don't see it being a quick turnaround, they're pretty busy.
A phone call to CRK would probably put you at ease. I really think you're over reacting. Grease it, lock it, use it.Dry, the knife has some play. With a decent amount of grease, there's almost zero play. Do they factor this grease space or no? I tried my best to measure with a digital caliper and came up with a difference of .002" between the pivot bushing ID and pivot pin OD. Also same between blade pivot ID and bushing OD. Just trying to get all the information I can before I send it in...
This is all just a shame!
I've had 3 CRKs pass through my hands. My first example, a knife art CF. Large 21 had a pivot that was tight enough to not want to dock but still very fluid. It never wore in. I sold it. I got back into CRK in the last year (its been 7 or so since I sold the first knife off) and bought a large inkosi. It's solid. Love the knife, missed the 21 and have been wanting to try Damascus. Bought this knife and having remembered how tight the previous one was, I was concerned that a little play could turn into something more. Hence the question.This is all just a shame!
I'm not a nit picky guy. I use all the gear I purchase. But since CRK and the sebenza line are synonymous with tight tolerances, wiggle is something that puts up a red flag.
You sure it's 2 thou? sounds like a lot. should be more along the lines of half a thou or 0.0005 shown in this thread:Dry, the knife has some play. With a decent amount of grease, there's almost zero play. Do they factor this grease space or no? I tried my best to measure with a digital caliper and came up with a difference of .002" between the pivot bushing ID and pivot pin OD. Also same between blade pivot ID and bushing OD. Just trying to get all the information I can before I send it in...
I had the same issue when I owned my cf. But I did tighten down the screw all the way. I miss that knife!Is it the all CF scale model? I have the KnifeArt cf Sebenza 21 and that knife had side to side play, but I realized I wasn’t tightening the pivot down all the way, and the reason I wasn’t was because the action would be way too super stiff when I would.
But now I crank it down all the way and lube the pivot with grease+KPL and I have a nice smooth action without the stiffness. Hope your issue gets resolved
