For whatever it's worth, I would put more of a beard on the woods version as well. I would make the beard on the tactical one come to a sharper point, and then apply a beard similar to the tactical one (but with more of a tanto point) to the woods one. That way you could drive the beard into the side of a stump and use have a stationary blade to use for making shavings, etc by moving the wood around the edge. I saw Turley do something similar and it seems like it could be really helpful if only one hand was working for some reason.
Also, with beard you can choke up on the neck more and get your hand right behind the cutting edge for using it more as a knife.
Plus, I just think that's going to be a lot of weight forward on a hatchet that length, and may leave it quite unbalanced sine there's not much of a pole. Speaking of the pole...I would keep a pole of some sort, so you have a dedicated impact point. Could be helpful for striking through ice, etc, and plus I think it just makes it more aesthetically pleasing.
