 - Jan 6, 2014
DMT has a 120 grit (silver colour) for skies and snowboards. That is where I start.
Then black(220), blue, red, green. Strop after green or go to a Belgian water stone first (~6000/8000grit)
If you have a triangle with a 90degree angle and the long arm is 3x the short one, the smallest angle is 20degrees
So angle blue/yellow is 90degree and yellow is 3x blue gives a 20degree angle between red and yellow.
(4 times is 15degrees)
is it really worth it to buy a diamond stone at such a low grit?? I figured the quality of the stone wouldn't matter at such low grits. but i wouldn't know
that's a handy little trick with the triangle im gonna have to remember that.
i still haven't decided how i want to set the angle for my grind but i do like your idea with a block at the ricasso. How do you keep the angle on the curve of the blade?
