I have always liked knives and after I felt the need for a hobby i could undertake at home in my spare time.
After watching and reading for a while i decided to try my hand at making my own knife.
The plan is to document it here and hopefully learn a lot from the experince and apply it to my future projects.
I looked at a lot of knives and settled on a design I liked and ultimately hoped wouldn't be too troublesome to complete
Out in my uncles shed i found some flat steel, (no idea what it is) it is a little too thick for what i wanted but for my first build i will take what i can get.
After cutting out my template i decided the handle was a little too short for my likeing so a quick snip and the handle got a little longer.
After cleaning up one side of the steel I then transferred the shape, I found pencil to be less than ideal but it did the job for me for now.
Then came the hard bit. I wasn't sure how i was going to cut out the profile but my uncle has a few tools around so i was able to give a few different ways a go.
Cut a few pieces off with a hacksaw but it must have been a cheap blade because after 3 cuts it had become blunt and a few teeth had gone missing.
I then shaped the top on the bench grinder, the angle grinder and a belt sander. I found the belt sander the best of the 3 to do this.
I then moved to the drill press to cut the bottom profile out and drilled a series of holes along the shape and cut through it with a cut off blade on the angle grinder.
After about an hour of filing by hand, using the angle grinder and belt sander I ended up with this. It didn't look quite right, the blade looked a little too deep and after laying my template back down on it i see where i have to take some more material off.
That was all i had time for tonight. hopefully I will get a few more hours on it this week.
I still have no idea what i will do for handle material or pins but I'm sure i will find something by the time i come to it.
