In bladsmth's instructions it says to get:
Mill bastard (or a magicut) file
second cut file
finishing file
Based upon the recommendations I've read I've been looking at Nicholson files on Amazon. They have:
16" Nicholson Rectangle Mill Bastard Single Cut
14" Nicholson Half Round Second Cut Double Cut
14" Nicholson Rectangular Medium Double Cut
14" Nicholson Rectangular Fine Single Cut
Couple questions...
1) I've been trying to find the longest files that I can thinking that the longer the file is the easier it will be to work with. The only Bastard Cut Double Cut they have is 10" which seems rather short. Is the Mill Bastard I've listed the correct version or should I be going for the smaller double cut version?
I also found a 14" Nicholson Magicut but am concerned that going from the Magicut which is supposed to leave a smooth finish to a Second Cut Double Cut would be going backwards in finish level?
2) I can't seem to find the second cut single cut. There are 12" Nicholson Medium Single Cut but I'm not sure where Medium lies in comparison to a second cut.
3) Is the Fine Single Cut what would be used as a finishing file? Or is finishing a different term like a the Bastard or Magicut?
4) I'm wanting to make a hunter style for when I go backpacking with a 4.5in blade and no Choil cut out. Probably out of 1095 since the 1084 isn't listed on Aldo's website right now. I'll be having it professionally heat treated. Is 1/8th going to be thick enough for batoning wood or should I be looking at 3/16th?
5)What size chainsaw file should I be using to cut my initial plunge by the ricasso to get the nice transition from flat to taper?
Any other suggestions would be appreciated
Thanks,
Andy Henderson
second cut file
finishing file
Couple questions...
Thanks,
Andy Henderson
