My first knife
Hey guys.
Real quick - does anyone know where to buy steel from in the Seattle area? I came back last week, after I made this knife in NY using all my Dad's and Grandpa's tools!
Here are 2 photos of the first knife I made.
Here was my process:
0. Buy 18"x5/32"x1-1/2" O1 steel and cut an 8" length.
1. Used a bench grinder to get the basic shape, drilled holes for handle.
2. Filed the bevel edge by hand, just eyeballing the angle using 2 jigs with a vise.
3. Sanded the metal with a 110 grit paper.
4. Sanded the metal with a 220 grit paper.
5. Additional edge sharpening with the course side of a double sided sharpening stone.
6. HARDENING - Got the blade red hot in wood stove, verified it was no longer magnetic, then quenched in motor oil around 100 degrees.
7. Sanded the blade 5 minutes after quenching to remove most of oil.
8. TEMPERING - Baked knife at 400 degrees in the oven 10 minutes after quenching for 2 hours.
9. Another sanding with 220 grit paper.
10. Handle (my Grandpa took care of this)
11. Still need to make sheath.
If anyone has any feedback, I'd appreciate it. I know it's not the greatest looking knife but I was using it to carve some wood already. In terms of improvements, these are a few of the things I want to do next time.
1. Start with 2 plunge cuts when making the bevel edge.
2. Give the bevel more depth so its closer to the spine.
3. Mark the center of the blade so it's easier to remove the same amount of metal on each side.
4. Start with an angle grinder to remove initial metal for bevel edge.
5. Finish bevel edge using files and get a consistent angle instead of eyeballing (I have 2 jigs, a sliding bevel, and a protractor but I don't know how to get the angle right).
6. More sanding - Home Depot only had 3 grits of sandpaper and that's not enough to really make it shine.
BTW, here's the knife I was using as a model. As you can see, I have a lot of improving to do on my 2nd knife.
I can't help on the steel supply (try your local fastenal). but you made a functional knife and have a good plan for improvements on the next one. I say that you are going in the right direction. Have fun !!
Good job.
You should be able to find wet sand paper at auto type stores up to 1000 grit or higher if you want.
looks good. I used to live in Bremerton, Wa I know there are a lot of metal shops near the Naval base. If you do some asking around I am sure you can find a supplier. If you can't find anyone I recommend admiral steel. You might want to check out a sears, they generally have a healthy variety of sand paper.
-Josiah
Chuck Bybee and Alpha Knife supply is in Samamish Wa.. He stocks quite a few good blade steels. He has been hard to reach lately though.
BTW good looking blade!
Congratulations! You've done something that most people in the world will never attempt, you made a tool from scratch. You're part of a very exclusive club now, you're a knife maker. That feeling of satisfaction of making a knife to the best of your ability will be there with every knife you make. Learn all you can from everyone you can, hang on and enjoy the ride. :thumbup:
Later,
Iz
You can e-mail me at my bladeforums user name at Yahoo.com. I'll send you my phone number so we can chat about where to get supplies in our area.
Good luck
BJ
Congrats on your first.It is no hope for you now, as there is no known cure for the desire to make each one better than the last! You are of to a great start, and you can only get better with each one.
thanks everyone for encouraging words.
i bought a sturdy shelf unit with a vise this weekend for 10 bucks, so I'm half way to setting up a shop out here in WA now for knife #2...
Got your e-mail. I'll give you a call this afternoon.
You are welcome to come over to my place to see how I do things. I'm still primitive by most maker's standards, but I have a forge and my garage is organized around knife making.
