My First Opinel
I've been carrying my #8 to back up a Case medium stockman lately, in my back pocket next to my wallet. I love how sharp the thin edge gets on a strop. Modded both of mine (I also have a #12) by dropping the point and sanding/oiling the handles, as well as taking down the high point of the "tail" on the butt. Makes 'em much more comfortable in my palm that way.
how far does that tang go?? Or is it just a stock blade?
Wonderful knives. Fun to Mod.
Best regards
Robin
A number 6 fixed blade.
[/url][/IMG]
Hi Shrapnel
The pivot pin hole is where I put the pin. I ground forward to the Opinel mark so gained a little and then cut the slot for a very tight fit. I worked the knife pretty hard, seems to be OK. I made the little knife for a striker and a kindling/ fatwood prep tool for my fire kit.
Best regards
Robin
Here is a pic of using it to help build my sons pinewood derby car:
Here are a couple of pic of the steps I took to force a patina on it--I have never done it before, so it was just me experimenting. I made a paste from some vinegar and mustard and let that sit on it for an hour or so. Then I sliced up a lime and stuck the blade in the slices and left that for an hour or two. I will post the results later. . .
View attachment 336084View attachment 336085
Etching has huge possibilities. The Opinel steel will turn almost black with just vinegar. You can do "hamons", stripes like ladder damascus, endless fun :D I did a huge friction folder for a friend, wrote his name on the blade with thinned mustard and let it dry until it was hard, then wrapped the blade with kleenex soaked in vinegar until it dried. When I washed the mustard off it left his name in a spectrum of blues and reddish with a black background. If you etch the blade dark and then filework, the filework just pops against the dark etch.
Have fun
Best regards
Robin
Here is how the patina turned out:
There were a few rust spots that I sanded off with some fine grit paper--it left scratches, but got the rust spots off.
Here are a couple of glamour shots:
And just for fun, here is a pic of my 75 lb sweetheart Piper.. .
Pinnah,
The handle on that #10 is perfect...mind sharing how you did it?
Russ, thanks for the kind words.
To answer your question, I'm not sure, as in I've not been able to replicate it.
More to the point, I've not touched 2 Opinels and gotten the same results ever. I find beech really unpredictable.
That #10 was the result of a failed attempt to dye it black. I used copious amounts of analine black dye (available at woodworking stores) as it supposed does better with the tight grained beech. But, it didn't get the handle universally black.
So, I tried to sand it off but found that dark grain had absorbed more dye than the light grain did. This left me with a tiger stripe of sort. I gave it another bath of Rit brown dye and that gave the light parts of the grain more warmth. Top coat is numerous applications of tung oil/varnish.
The #8 next to it was done with Rit brown dye alone. You'll note that the #8 took on a deeper, redder brown than the #10 and you'll also note that the #8 has no where near the amount of interesting grain in it. The #10 certainly came out dramatically but I've really no idea how to replicate it. Gotta get lucky with the grain.
View attachment 336496View attachment 336497
View attachment 336498View attachment 336499
That's a pretty Doberman you have there, I bred them for years. If you want to darken the etch on your Opie try wrapping the blade in paper towel and soaking it in vinegar, I use red wine vinegar but it all works. If you wrinkle the paper towel you can play with patterns. Try to dry it quickly, like over a heat vent. then wipe the blade down with mineral oil.
Best regards
Robin
"HOLY SCAREY SHARP BATMAN"
I just got my #6 in the mail yesterday, and was surprised at how small it was. I have a #8 with the walnut handle on order also. I immediately named it Oppie. The blade felt sharp to my finger tips, but had a very obvious burr on it. Not being sure how to sharpen it since it was such a thin blade. (carbon steel) I decided not to grind a bevel on it with my paper wheels. So, I just proceeded to knock the burr off with the slotted wheel only, and then for good measure, I ran the other side of the blade on the slotted wheel also. I hit it almost flat, with just barely lifting the back edge of the blade off the wheel. Woowser! This thing is razor blade sharp. It just heads for the hair on my arm and they just give up and pop off on their own it seems. Never owned a knife that got that sharp so quick. I am talking 5 seconds here total. It will push cut phone book paper cleanly with no effort. Like slicing butter with a hot wire. Can you tell, I am impressed.
I don't know how easy the stainless blade on the #8 will sharpen up, but this carbon blade is impressive. I can see how this type blade would be a good blade to have as a small survival knife. All you need is a rock or a coffee cup to keep it sharp. Me and Oppie are going to be good friends.
Blessings,
Omar
Blessings,
Omar
Funny, my first Opinel is Opie. Mine didn't have the issues noted in the OP though.
Blessings,
Omar
Using paper wheels or even slotted wheels can be considered almost criminal over kill for an Opinel.:D
These things are soooo easy to sharpen with traditional means, that a coffee mug or any old pocket stone is good enough for a shaving edge, with a light stropping on the back of an old belt. Although thin, the blade is actually a convex grind. This is a working mans knife, and is designed to be easy to sharpen up literally anywhere at any time. A smooth stone from a creek and a boot top is good.
Carl.
You are probably right Carl. After using the slotted wheel to buff the burr off, I wondered if I could have done the same job with just my leather strop. It was all so easy that I was really just astounded. It made me realize why these knives have survived for so long. They are a peasant or farmer's knife that he could use every day and return to a very sharp knife with no more than a smooth rock and his boot or trousers for that matter. Makes you realize that progress isn't always progress in some things. Have a Blessed day!
Blessings,
Omar
Blessings,
Omar
I think you are right, Omar. Progress is not always progress. I really do believe that one of the keys to why the Opinel has survived for so long, like the Mercator K55 and SAK, is that for most of the rest of the world, people just want a knife to cut something. They are not knife nuts, are not obsessed with the latest of blade steels that will skin a whole herd of deer without resharpening. They just want to make dinner, or lunch, or open a package, or cut a piece of rope. And when that knife gets dull, they don't want a big hassle getting it sharp again. Some poor working guy out in a farm field, or construction site, or loading dock, just needs a sharp tool.
I remember when I was stationed for a while in Italy. We were doing some runway extension work at an air force base, and some of us had housing just off base. Every evening, these old Italian ladies that were getting ready to make supper, would come out and strop their knives on the smooth stones of the front porch. These old stone homes had maybe been in use since the time of the Borgias, and the stones that made up the front steps were worn smooth with time. They would take those old almost black bladed butcher knives and get a good working edge in just a few minutes. My guess is those old knives were maybe a mild temper equivalent of 1095, if that. But for them it works just fine.
I think Opinels and other low priced but high value knives have their success in that the vast bulk of people who buy them are just looking for a cutting tool that will work, won't break the bank, and is easy to sharpen. Come to think of it, what more do we really need? :)
Opinel's, Mercators, and Douk-Douk's are those knives for the working masses, and they ahve lasted because they do work well at their intended task.
Carl.
I must say I am drawn towards these knives myself... too bad all (the ones of any practical size) come with a lock, which I'm sure you know is frowned upon over here... my sort of knife this. simple, working mans tool, cheap and easy to sharped. something you can trust. I like that.
My number 8 just arrived. It's my first. First impression is WHERE IS THA T OPPIE TUNING THREAD. I can see the Potential here but it is going to take a little work. The knife is sharp but a few minutes on the fine stone and its poppin sharp that's nice. I am going to use it for a few days then after I find and read that tune up thread again I plan on fiddling with it some. As it arrived I have to say for the money I don't think anyone could find much to complain about. I think I'll go ahead and order one of each size.
