- Jun 11, 2006
I have been for a long time wanting to try my hand at inlaying wire into knife handles so i made an inlay tool at work today and when got home gave it a shot. I used a copper wire of sorts. it was a supper ling curl that came off a part i made on the lath and i kept it. i hammered it flat and annealed it. my lines are not a smooth as i would like but this was my first attempt. what do you think and do you have any tips that will help me out next time.
I am sure if i sanded down the wood more the lines would clean up more as after i inlay the wire i weted the surface and the wood swelled quite a bit around the wire. One question i have is how do you cut off the wire after you get to the end of a run? I would get to the end and take my inlay slot cutter tool and mark the wire then pull the wire out and cut it off and re-inlay it. Thanks
