A couple of weeks ago i made a outdoors knife for myself out of O1 steel, and after quite a lot of abuse while batoning it snapped in half.
First i just thought i abused it to much, but then out of curiosity i did some research, and found that the fracture is probaply a intercristallin fracture.
These fractures, as i read, only occure due to grain boundry embrittlement. And this has only negativeconsequences for the steel.
If the steel had been heatreated correctly the fracture should have ben transcristalline, that usually results in a much smoother surface.
I have to admit that i quenched the steel in oil at about 1000°c meshured with a IR-Thermometer where it should have been somthing like 830°.
but if someone with the metallurgic expertise could tell me the mechanism at work i would be very greatful.
Further online research also told me, that there are only 2 reasons for such grain boundry embrittlement.
1. Hydrogen grain boundry embrittlement
2. Carbide grain boundry embrittlement.
Hydrogen grain boundry embrittlement happens when atomic hydrogen contacts the surface of a steel. this could have happend during heating, since i used a propane torch. one of the porducts of burning propane is water and that can react with iron to hydrogen and ironoxyde.
Nevertheless i think it is unlikly to be the cause for this faliure since a lot of people use this heating method.
Carbide grain boundry embrittlement can be caused by flawed heat treatment. So by quenching but also by tempering. (I tempered 2x 1h 200°c in a kitchen oven)
If someone could confirm that the error is defenetly in the to high quenching temperature, i would be verry grateful.
No matter what i think o learned my lesson on extreme batoning and listening to the temperature recomendations after all this was only my 5th knife.
Sorry for my bad english and by the way this is my first post here, so hello guys!
SOURCES:
https://tu-dresden.de/die_tu_dresde...rofessuren/wpc/risse_und_fraktographie_teil_1
http://www-e.uni-magdeburg.de/wiwf/...Schadensanalyse 2014 - 2015 - Vorlesung 9.pdf
https://books.google.de/books?id=-U...r+Schadensf%C3%A4lle.html?autr="Günter+Lange"
http://aquensis-verlag.e-bookshelf....r+Schadensf%C3%A4lle.html?autr="Günter+Lange"
https://en.wikipedia.org/wiki/Fracture
SOURCES:
