- Dec 23, 2006
Well my knife got done hob knobbing around the country and I picked it up this morning. Again I cant thank everyone enough Jason,Paul and Jim.
Again I would like to stress how much I like this knife .
The knife weights in at 18 ounces and feels like it is well under a pound
I am going to explain a little about what to me makes a good Fighting Bowie compared to a good Fighter. For a fighter lets hypothetically use the one of the most famous fighters of all the Loveless Big Bear. Now before anyone gets all worked up I am not comparing this knife to a Loveless I just want to compare a good fighter with a good fighting bowie and the Loveless is a lovely visual for our hypothetical fighter.
The difference to me between our fighter and are fighting Bowie are not so much your stance or grip. You can assume saber grip and thrust with both you can snap cut and I guess even back cut with both. But the difference is the power. When you change direction quickly the Fighter would just dance in your hand it will change direction effortlessly. The Fighting Bowie and I mean a proper fighting Bowie will do the same but at the moment you change direction from say a thrust to a back cut or the most noticeable combo a jabbing snap cut to a back cut at the moment you change direction there is a slight lag.... old momentum which can be your best friend or your worse enemy slightly takes hold of your blade . If it wrenches your wrist your knife is to heavy or balanced badly but if and I mean just for a second it kinda makes your wrist load that is where the magic of the proper weighted and balanced piece becomes magic and you can fell the snap and power of the fighting Bowie.
What this means is the man who thrusts for the face with the fighter and the opponent side steps the one who thrusts finds his blade out in the air where the throat of his opponent used to be so he gracefully back cuts his opponents check leaveing a ever so beautiful slash on his foes check. If he was using a proper Fighting Bowie the back cut would of been like an eagles claw tearing the opponents check and maybe even knocking out a tooth or so. The point I am trying to make is power end things quickly and any defensive situation you want it to end quickly in your favor and the proper Fighting Bowie helps you in this task.
So in my opinion a Fighting Bowie is not what you would consider a typical fighter it is also not a big old South Western style Bowie it is basically a Combo of the 2
They hit like a freight train and load like a good fly rod and give that magical blend of speed and power
I hope everyone that got one of these sets up a few targets and does some work with them .. A real fun exercise is to hang a Kong ball from a string set the ball in motion with a little thrust then work clockwise and counter clock wise around the ball keeping it moving with little snap cuts and thrusts and the occasional back cut. At first you will cut the string a lot but after a while your targeting will improve and you will have the ball dancing around Every now and then load your wrist and snap cut hard or back cut hard and see the ball fly away like ya cracked a home run even though your hand just flicked the wrist... that is the power of a good fighting bowie.
My pics are so anemic compared to Coops but here are some pics in hand and One for Will of I hope the Angle he is looking for
Thanks for looking
Even the mighty Jack bows his head
He thinks I am going to stick a Hog
Thanks for looking
