- Nov 8, 2009
If I may tell a secret, my file guide is home-made and to date I haven't even bothered to harden it. They do need to be fairly thick for rigidity though.I think I understand the principle here , I'm only using hand files on this so the recurve should be less likely to be rounded ( in theory in my head) my only problem is my file guide that I made sucks balls and is thin and bent up . I doled out $50 for a nice one from jantz supply and it's sitting in a box with the rest of an order at the US border right now waiting for the postal strike to end. I want to get going on this knife but don't want to shoot myself in the foot at the start. I rounded the bottom of the handle a bit on that mini drop point this afternoon , it looks smoother now then that pic from earlier today.
The hand-lapping method can seem like a pain because you will have to move the paper and get fresh abrasive fairly often, especially at the beginning, but as the plunge begins to match the radius of the plate the abrasive will last longer. I usually start with 120 or 150 grit but if the plunges are really ugly or have to move back I use 80 grit and put a layer of tape over most of the blade as well to protect it from stray grit as it rubs over the masked sandpaper. Light pressure works better when using the coarse grits, otherwise you just rip the abrasive clean off the paper.
The real trick with this and all hand finishing is to pretend you are trying to use as much sandpaper as you can. Really. Not trying to throw away half-used sheets, but to use reasonably fresh abrasive with every pass. When it feels used up, it is, even if you've only made a few passes. Fewer things in knifemaking will waste more time, in the long run, than trying to get extra mileage out of used up abrasive. I'd be a few years younger if I had all that time back.
