Bawanna
Moderator
- Dec 19, 2012
Well heck, I did a nice post with pictures and then the connection went south, here we go again, round two.
Checkering 101 in 500 words or less in B flat.
First you determine what shape and size of diamonds you want, now days 3 to 3 1/2 times as high as they are wide. Used to be down to even 1 to 1 just diagonal boxes. The size is determined by the lines per inch. I usually do 20, many factory rifles etc are 18, the finer you go the more delicate they are and less grippy. Still very nice and high end shotguns etc will have very fine line checkering.
The shape of the diamonds determines the angle of the starter lines or master lines as they are referred to. They are marked with a pencil and cut with a v tool or veiner then made straight and deepened a bit with a single line cutter.
The tools
There are single line cutters in fine and course, there are double and triple head cutters, some are designed to cut on the pull rather than the push to work away from borders and such. Some double cutters have teeth on both sides, some have teeth on one side and smooth on the other to help guide in the previous line, so you stay nice an parallel. Crooked is not good and it's very easy to get off and have lines merge or get too far apart, that's where the patience part comes in. Also kind of have to have your mind right. If your not in the mood to checker it's best to go play with knives or something until you are in the mood.
The cutters work like a tiny little file in a back and forth sawing motion. Very time consuming to say the least.
Double cutter on the left, single cutter on the right.
A double cutter with a smooth side and a skip line cutter on the right. It is used when you want to mix in larger diamonds amongst your standard diamonds. Like this.
And the mess that goes along with shaping a square piece of wood into something else.
Here's some pins I'm pondering inlaying into a set of grips. They go up for auction on another forum. Second year I've made them. They apparently come up with a different pin each year.
Hope that was less than 500 words, I'm not gonna go back and count. Guess I'll go out and do some cleaning up a bit. Thank goodness for shop vacs huh?
The tools
